주요 콘텐츠로 건너뛰기
How to Replace a Three-Prong Plug on a Power Strip
필요한 것
  1. How to Replace a Three-Prong Plug on a Power Strip, Three-Pole Plug: 1 단계, 이미지 1개 중 1개
    • Unplug the power strip and place it on a flat, non-metal surface.
  2. How to Replace a Three-Prong Plug on a Power Strip: 2 단계, 이미지 2개 중 1개 How to Replace a Three-Prong Plug on a Power Strip: 2 단계, 이미지 2개 중 2개
    • Cut near the base of the original plug, all the way through. Dispose of the old plug.
  3. How to Replace a Three-Prong Plug on a Power Strip: 3 단계, 이미지 1개 중 1개
    • Before attempting to work with the wires, insert the cord into a piece of heat shrink tubing. This will help to safely seal the wires later.
  4. How to Replace a Three-Prong Plug on a Power Strip: 4 단계, 이미지 2개 중 1개 How to Replace a Three-Prong Plug on a Power Strip: 4 단계, 이미지 2개 중 2개
    • Examine the 3 wires inside. You should see green, white, and black. Snip off any stray wires over a trash can.
  5. How to Replace a Three-Prong Plug on a Power Strip: 5 단계, 이미지 1개 중 1개
    • Strip back about 1/2 inch of the Wire with the wire strippers.
    • Braid the wires by gently twisting each strand so they stay with their same color wires.
  6. How to Replace a Three-Prong Plug on a Power Strip: 6 단계, 이미지 1개 중 1개
    • Unscrew the hinge on the new plug, set the screw somewhere safe for later.
  7. How to Replace a Three-Prong Plug on a Power Strip: 7 단계, 이미지 1개 중 1개
    • Make sure you have 3 different colored screws. Gold or dark colored, green and silver or light colored.
  8. How to Replace a Three-Prong Plug on a Power Strip: 8 단계, 이미지 3개 중 1개 How to Replace a Three-Prong Plug on a Power Strip: 8 단계, 이미지 3개 중 2개 How to Replace a Three-Prong Plug on a Power Strip: 8 단계, 이미지 3개 중 3개
    • Pair the black wire to the gold or dark colored screw. Once twisted around the screw clockwise, tighten it.
    • Pair the green wire to the green colored screw. Once twisted around the screw clockwise tighten it.
    • Pair the white wire to the silver or light colored screw. Once twisted around the screw clockwise, tighten it.
  9. How to Replace a Three-Prong Plug on a Power Strip: 9 단계, 이미지 3개 중 1개 How to Replace a Three-Prong Plug on a Power Strip: 9 단계, 이미지 3개 중 2개 How to Replace a Three-Prong Plug on a Power Strip: 9 단계, 이미지 3개 중 3개
    • Close up the new plug and screw it tightly shut.
    • Make sure the plug closes well with the cables and it is not blocking the closing mechanism.
  10. How to Replace a Three-Prong Plug on a Power Strip: 10 단계, 이미지 3개 중 1개 How to Replace a Three-Prong Plug on a Power Strip: 10 단계, 이미지 3개 중 2개 How to Replace a Three-Prong Plug on a Power Strip: 10 단계, 이미지 3개 중 3개
    • Seal the Heat Shrink Tubing by holding the flame of a lighter directly on the tubing, moving it back and forth until the tubing molds itself to the wires.
    • Do not let the flame linger for too long, or you run the risk of ruining the seal.
    • If heat shrink is unavailable, electrical tape works just as well.
  11. How to Replace a Three-Prong Plug on a Power Strip: 11 단계, 이미지 2개 중 1개 How to Replace a Three-Prong Plug on a Power Strip: 11 단계, 이미지 2개 중 2개
    • Connect to the wall and enjoy your restored power strip.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Arahey Garay
회원 가입일: 03/21/21
259 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 68
전체 시간: 3,773
