주요 콘텐츠로 건너뛰기
How to Replace a Toilet's Shut-Off Valve
필요한 것
  1. How to Replace a Toilet's Shut-Off Valve, Shut-Off Valve: 1 단계, 이미지 1/2 How to Replace a Toilet's Shut-Off Valve, Shut-Off Valve: 1 단계, 이미지 2/2
    • Locate the water main line (typically found in your basement).
    • Turn off the water main line by rotating the knob clockwise.
  2. How to Replace a Toilet's Shut-Off Valve: 2 단계, 이미지 1/2 How to Replace a Toilet's Shut-Off Valve: 2 단계, 이미지 2/2
    • Go to the lowest level of your house and turn the faucet on at any sink.
    • Keep the faucet running until it stops spewing water. If the faucet doesn't stop, you likely turned the wrong valve in Step 1.
  3. How to Replace a Toilet's Shut-Off Valve: 3 단계, 이미지 1/1
    • Flush the toilet (the one that needs the valve to be replaced).
  4. How to Replace a Toilet's Shut-Off Valve: 4 단계, 이미지 1/2 How to Replace a Toilet's Shut-Off Valve: 4 단계, 이미지 2/2
    • Turn the toilet shut off valve counter clockwise.
  5. How to Replace a Toilet's Shut-Off Valve: 5 단계, 이미지 1/2 How to Replace a Toilet's Shut-Off Valve: 5 단계, 이미지 2/2
    • Using the wrench, disconnect the tank hose from the pipe by turning the wrench clockwise until the hose is completely disconnected from the pipe.
  6. How to Replace a Toilet's Shut-Off Valve: 6 단계, 이미지 1/2 How to Replace a Toilet's Shut-Off Valve: 6 단계, 이미지 2/2
    • Rotate the toilet shut-off valve clockwise with the wrench until the valve comes off from the pipe.
    • Slide the new valve onto the pipe and tighten the valve onto the pipe with the wrench.
    • Using the wrench reconnect the hose to the pipe by rotating the wrench counter clockwise.
    • Turn the water main on rotating the knob counter clockwise.
결승점
Jayden Scott-Douglas
회원 가입일: 01/08/21
133 평판
안내서 1개 작성함
York University, Team S1-G25, O'Regan Winter 2021 York University, Team S1-G25, O'Regan Winter 2021 회원
YORK-O'REGAN-W21S1G25
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 14
30일 전: 112
전체 시간: 3,091
