주요 콘텐츠로 건너뛰기
How to Replace a Toilet's Shut-Off Valve
필요한 것
  1. How to Replace a Toilet's Shut-Off Valve, Shut-Off Valve: 1 단계, 이미지 2개 중 1개 How to Replace a Toilet's Shut-Off Valve, Shut-Off Valve: 1 단계, 이미지 2개 중 2개
    • Locate the water main line (typically found in your basement).
    • Turn off the water main line by rotating the knob clockwise.
  2. How to Replace a Toilet's Shut-Off Valve: 2 단계, 이미지 2개 중 1개 How to Replace a Toilet's Shut-Off Valve: 2 단계, 이미지 2개 중 2개
    • Go to the lowest level of your house and turn the faucet on at any sink.
    • Keep the faucet running until it stops spewing water. If the faucet doesn't stop, you likely turned the wrong valve in Step 1.
  3. How to Replace a Toilet's Shut-Off Valve: 3 단계, 이미지 1개 중 1개
    • Flush the toilet (the one that needs the valve to be replaced).
  4. How to Replace a Toilet's Shut-Off Valve: 4 단계, 이미지 2개 중 1개 How to Replace a Toilet's Shut-Off Valve: 4 단계, 이미지 2개 중 2개
    • Turn the toilet shut off valve counter clockwise.
  5. How to Replace a Toilet's Shut-Off Valve: 5 단계, 이미지 2개 중 1개 How to Replace a Toilet's Shut-Off Valve: 5 단계, 이미지 2개 중 2개
    • Using the wrench, disconnect the tank hose from the pipe by turning the wrench clockwise until the hose is completely disconnected from the pipe.
  6. How to Replace a Toilet's Shut-Off Valve: 6 단계, 이미지 2개 중 1개 How to Replace a Toilet's Shut-Off Valve: 6 단계, 이미지 2개 중 2개
    • Rotate the toilet shut-off valve clockwise with the wrench until the valve comes off from the pipe.
    • Slide the new valve onto the pipe and tighten the valve onto the pipe with the wrench.
    • Using the wrench reconnect the hose to the pipe by rotating the wrench counter clockwise.
    • Turn the water main on rotating the knob counter clockwise.
결승점
작성자
1다른 기여자 명과 함께
Jayden Scott-Douglas
회원 가입일: 01/08/21
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 17
지난 30일: 46
전체 시간: 3,758
