주요 콘텐츠로 건너뛰기
How to Replace a Transition Strip (T Molding)
필요한 것
  1. How to Replace a Transition Strip (T Molding), Transition Strip (T Molding): 1 단계, 이미지 1/1
    • Measure the exact width of the doorway using a tape measure.
  2. How to Replace a Transition Strip (T Molding): 2 단계, 이미지 1/3 How to Replace a Transition Strip (T Molding): 2 단계, 이미지 2/3 How to Replace a Transition Strip (T Molding): 2 단계, 이미지 3/3
    • Mark the T molding based on the doorway measure.
    • Cut the T molding using a sharp saw (table saw).
    • Cutting the T molding can be done for free at the place of purchase.
    • If you don't have access to a sharp saw, cut the T molding using a jigsaw and use sanding paper to soften the end.
  3. How to Replace a Transition Strip (T Molding): 3 단계, 이미지 1/3 How to Replace a Transition Strip (T Molding): 3 단계, 이미지 2/3 How to Replace a Transition Strip (T Molding): 3 단계, 이미지 3/3
    • Remove the old T molding.
    • You can use a pry bar to loosen the T molding.
  4. How to Replace a Transition Strip (T Molding): 4 단계, 이미지 1/2 How to Replace a Transition Strip (T Molding): 4 단계, 이미지 2/2
    • Use a utility knife to remove all the glue or any material used to keep the old T molding in place.
    • You may use a scraper instead of a utility knife.
    • Clean up the area thoroughly.
  5. How to Replace a Transition Strip (T Molding): 5 단계, 이미지 1/1
    • Apply the glue evenly to the gap.
  6. How to Replace a Transition Strip (T Molding): 6 단계, 이미지 1/3 How to Replace a Transition Strip (T Molding): 6 단계, 이미지 2/3 How to Replace a Transition Strip (T Molding): 6 단계, 이미지 3/3
    • Insert the T molding into the gap.
    • Press the T molding firmly onto the ground.
    • No gap should exist between the T molding and the floorings.
  7. How to Replace a Transition Strip (T Molding): 7 단계, 이미지 1/2 How to Replace a Transition Strip (T Molding): 7 단계, 이미지 2/2
    • Tape the T molding onto the floor.
    • This step ensures the T molding stays in place until the glue dries.
    • Wait 24 hours for the glue to dry.
    • Remove the tapes.
결론
Rojean Noorinayer
회원 가입일: 05/12/21
145 평판
안내서 1개 작성함
York University, Team S1-G19, Melo-Thaiss Summer 2021 York University, Team S1-G19, Melo-Thaiss Summer 2021 회원
YORK-MELO-THAISS-SU21S1G19
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 47
30일 전: 176
전체 시간: 4,699
