주요 콘텐츠로 건너뛰기
Pioneer Quartz PLL PL-550 Cartridge, Stylus, and Headshell Replacement
필요한 것
  1. Pioneer Quartz PLL PL-550 Cartridge, Stylus, and Headshell Replacement, Cartridge, Stylus, Headshell: 1 단계, 이미지 1개 중 1개
    • Identify the headshell by opening the turntable dust cover.
  2. Pioneer Quartz PLL PL-550 Cartridge, Stylus, and Headshell Replacement: 2 단계, 이미지 1개 중 1개
    • Identify the stylus (needle housing) on the headshell and gently remove it from the cartridge by wiggling it carefully. Dispose of the stylus.
  3. Pioneer Quartz PLL PL-550 Cartridge, Stylus, and Headshell Replacement: 3 단계, 이미지 1개 중 1개
    • Locate the tonearm weight located at the base of the headshell. While holding the headshell, turn the tonearm weight to the right to disconnect the headshell from the tonearm.
  4. Pioneer Quartz PLL PL-550 Cartridge, Stylus, and Headshell Replacement: 4 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver and remove the screws to free the cartridge. Retain the screws for reinstallation.
    • Use standard turntable head screws found at a local audio shop if missing.
  5. Pioneer Quartz PLL PL-550 Cartridge, Stylus, and Headshell Replacement: 5 단계, 이미지 1개 중 1개
    • Locate the wires on the underside of the headshell and carefully disconnect the wires from the pins of the cartridge.
  6. Pioneer Quartz PLL PL-550 Cartridge, Stylus, and Headshell Replacement: 6 단계, 이미지 1개 중 1개
    • Replace with a new cartridge by plugging the pins of the new cartridge into the wires.
    • Match the color of the wires to the color of the pins.
    • Using the Phillips #0 screwdriver, re-screw the cartridge into the headshell the same way it was removed.
  7. Pioneer Quartz PLL PL-550 Cartridge, Stylus, and Headshell Replacement: 8 단계, 이미지 1개 중 1개
    • Insert a new stylus (needle housing) into the cartridge before remounting the headshell onto the tonearm.
  8. Pioneer Quartz PLL PL-550 Cartridge, Stylus, and Headshell Replacement: 9 단계, 이미지 1개 중 1개
    • Connect the newly assembled headshell into the tonearm and tighten until secure.
    • Do not overtighten.
  9. Pioneer Quartz PLL PL-550 Cartridge, Stylus, and Headshell Replacement: 10 단계, 이미지 1개 중 1개
    • Test the new needle and allow for a break-in period.
결승점
다른 11명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Javier Torres
회원 가입일: 02/24/15
413 평판
안내서 1개를 작성함
Cal Poly, Team 23-3, Green Winter 2015 Cal Poly, Team 23-3, Green Winter 2015 회원
CPSU-GREEN-W15S23G3
6 회원들
안내서 13개를 작성함
4가이드 댓글
"on any turntable"? These instructions are only for one specific tonearm and cartridge and apply to a minority of cartridges. This claim is plainly bogus and anyone with a different cartridge is likely to find the instructions useless and potentially hazardous to their equipment.
Howard - 답글
Just commenting to disagree with above. Excellent tutorial and my audio technical cartridge and headshell are similar so it solved my issue. Thanks for the article.
Craig Smith - 답글
Yeah, I thought the above tutorial was very informative and easy to understand
Philip - 답글
You dont mention realigning the needle, as you've pulled the whole cartridge off. Some will just screw the new cartridge on and play
Troll cartridge - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 65
전체 시간: 57,457
