주요 콘텐츠로 건너뛰기
How to Replace a Turntable Cartridge, Stylus, and Headshell
필요한 것
  1. How to Replace a Turntable Cartridge, Stylus, and Headshell, Cartridge, Stylus, Headshell: 1 단계, 이미지 1/1
    • Identify the headshell by opening the turntable dust cover.
  2. How to Replace a Turntable Cartridge, Stylus, and Headshell: 2 단계, 이미지 1/1
    • Identify the stylus (needle housing) on the headshell and gently remove it from the cartridge by wiggling it carefully. Dispose of the stylus.
  3. How to Replace a Turntable Cartridge, Stylus, and Headshell: 3 단계, 이미지 1/1
    • Locate the tonearm weight located at the base of the headshell. While holding the headshell, turn the tonearm weight to the right to disconnect the headshell from the tonearm.
  4. How to Replace a Turntable Cartridge, Stylus, and Headshell: 4 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver and remove the screws to free the cartridge. Retain the screws for reinstallation.
    • Use standard turntable head screws found at a local audio shop if missing.
  5. How to Replace a Turntable Cartridge, Stylus, and Headshell: 5 단계, 이미지 1/1
    • Locate the wires on the underside of the headshell and carefully disconnect the wires from the pins of the cartridge.
  6. How to Replace a Turntable Cartridge, Stylus, and Headshell: 6 단계, 이미지 1/1
    • Replace with a new cartridge by plugging the pins of the new cartridge into the wires.
    • Match the color of the wires to the color of the pins.
    • Using the Phillips #0 screwdriver, re-screw the cartridge into the headshell the same way it was removed.
  7. How to Replace a Turntable Cartridge, Stylus, and Headshell: 8 단계, 이미지 1/1
    • Insert a new stylus (needle housing) into the cartridge before remounting the headshell onto the tonearm.
  8. How to Replace a Turntable Cartridge, Stylus, and Headshell: 9 단계, 이미지 1/1
    • Connect the newly assembled headshell into the tonearm and tighten until secure.
    • Do not overtighten.
  9. How to Replace a Turntable Cartridge, Stylus, and Headshell: 10 단계, 이미지 1/1
    • Test the new needle and allow for a break-in period.
결승점
다른 9명이 해당 안내서를 완성하였습니다.
Javier Torres
회원 가입일: 02/24/15
385 평판
안내서 1개 작성함
Cal Poly, Team 23-3, Green Winter 2015 Cal Poly, Team 23-3, Green Winter 2015 회원
CPSU-GREEN-W15S23G3
6 회원들
안내서 13개 작성하였습니다
댓글 2개
"on any turntable"? These instructions are only for one specific tonearm and cartridge and apply to a minority of cartridges. This claim is plainly bogus and anyone with a different cartridge is likely to find the instructions useless and potentially hazardous to their equipment.
Howard - 답글
Just commenting to disagree with above. Excellent tutorial and my audio technical cartridge and headshell are similar so it solved my issue. Thanks for the article.
Craig Smith - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 42
30일 전: 183
전체 시간: 54,903
