주요 콘텐츠로 건너뛰기
How to Replace a Valve Spring on a Trumpet
필요한 것
  1. How to Replace a Valve Spring on a Trumpet, valve spring: 1 단계, 이미지 2개 중 1개 How to Replace a Valve Spring on a Trumpet, valve spring: 1 단계, 이미지 2개 중 2개
    • To pull out the valve, first twist the top of the valve open counterclockwise to detach it from the rest of the valve.
    • Pull the valve out of the trumpet.
  2. How to Replace a Valve Spring on a Trumpet: 2 단계, 이미지 2개 중 1개 How to Replace a Valve Spring on a Trumpet: 2 단계, 이미지 2개 중 2개
    • Near the top of the valve, twist the top part of the screw compartment off to access the screw.
    • Pull the old spring out and replace with the new one.
    • Reassemble the valve the same way it came apart.
  3. How to Replace a Valve Spring on a Trumpet: 3 단계, 이미지 2개 중 1개 How to Replace a Valve Spring on a Trumpet: 3 단계, 이미지 2개 중 2개
    • Before inserting the valve back into the trumpet, put enough valve oil on the valve so that that the surface is wet, but not dripping.
    • Insert the valve into the trumpet, and screw in the top clockwise.
    • Be sure to grasp the top of the valve and twist until a clicking sound is heard and the valve locks in place to ensure that the trumpet is ready for playing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Isaac Trotta
회원 가입일: 02/24/15
125 평판
안내서 1개를 작성함
Cal Poly, Team 23-4, Green Winter 2015 Cal Poly, Team 23-4, Green Winter 2015 회원
CPSU-GREEN-W15S23G4
7 회원들
안내서 15개를 작성함
1가이드 댓글
I cannot manage to take out my valve it is so hard It’s a brand new trumpet sound like come out and then I don’t have valve oil
Flavio - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 20
지난 30일: 45
전체 시간: 8,958
