주요 콘텐츠로 건너뛰기
How to Replace a Watch Strap
필요한 것
  1. How to Replace a Watch Strap, Watch Strap: 1 단계, 이미지 1개 중 1개
    • Begin by laying a soft towel or fabric on a table.
    • This will prevent accidental scratches during the repair.
    • We will be performing all repairs from the back of the watch, to avoid scratching the visible watch face.
  2. How to Replace a Watch Strap: 2 단계, 이미지 2개 중 1개 How to Replace a Watch Strap: 2 단계, 이미지 2개 중 2개
    • Before you begin, consider practicing with your tool to compress the bar.
    • Hold the watch with the face in your palm, with one end of the strap free to move.
  3. How to Replace a Watch Strap: 3 단계, 이미지 2개 중 1개 How to Replace a Watch Strap: 3 단계, 이미지 2개 중 2개
    • Insert your Spring Bar tool into the gap between the end of the watch strap and the watch body.
    • Press down and compress the spring. By pushing the bar away from the body, one end of the spring bar should come loose.
  4. How to Replace a Watch Strap: 4 단계, 이미지 2개 중 1개 How to Replace a Watch Strap: 4 단계, 이미지 2개 중 2개
    • Being cautious as to not damage the body or spring bar, slide the bar out from its hole and remove the strap.
    • Set this half of the strap with the spring bar aside until we remove the other strap.
  5. How to Replace a Watch Strap: 5 단계, 이미지 3개 중 1개 How to Replace a Watch Strap: 5 단계, 이미지 3개 중 2개 How to Replace a Watch Strap: 5 단계, 이미지 3개 중 3개
    • Repeat steps 2-4 to remove the other end of the watch strap.
  6. How to Replace a Watch Strap: 6 단계, 이미지 3개 중 1개 How to Replace a Watch Strap: 6 단계, 이미지 3개 중 2개 How to Replace a Watch Strap: 6 단계, 이미지 3개 중 3개
    • Replace the old or damaged watch straps by simply sliding the spring bars out and into the new straps
    • Be careful not to put the new straps on the wrong side of the body.
  7. How to Replace a Watch Strap: 7 단계, 이미지 3개 중 1개 How to Replace a Watch Strap: 7 단계, 이미지 3개 중 2개 How to Replace a Watch Strap: 7 단계, 이미지 3개 중 3개
    • Begin the reassembly by sliding the bottom of the spring bar into its hole on the watch body.
    • Remember, always work from the back of the watch to prevent visible scratches.
    • Using your spring bar tool, compress the bar and slide back into place.
    • The spring bar should click when installed correctly.
  8. How to Replace a Watch Strap: 8 단계, 이미지 3개 중 1개 How to Replace a Watch Strap: 8 단계, 이미지 3개 중 2개 How to Replace a Watch Strap: 8 단계, 이미지 3개 중 3개
    • Repeat step 7 on the other side of the watch.
    • Give the watch a tug to make sure all parts are installed correctly.
결론
You have completed the fix! We hope this guide has helped.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
domenicruffino
회원 가입일: 09/29/15
308 평판
안내서 1개를 작성함
Cal Poly, Team 14-2, Green Fall 2015 Cal Poly, Team 14-2, Green Fall 2015 회원
CPSU-GREEN-F15S14G2
4 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 66
전체 시간: 11,757
