주요 콘텐츠로 건너뛰기
How to Replace a Window Arm for an Out-Swinging Casement Window
필요한 것
  1. How to Replace a Window Arm for an Out-Swinging Casement Window, Window Arm: 1 단계, 이미지 1/2 How to Replace a Window Arm for an Out-Swinging Casement Window, Window Arm: 1 단계, 이미지 2/2
    • Unlock the window lock by flipping both switches up until they are pointed horizontally outwards, facing the user.
  2. How to Replace a Window Arm for an Out-Swinging Casement Window: 2 단계, 이미지 1/3 How to Replace a Window Arm for an Out-Swinging Casement Window: 2 단계, 이미지 2/3 How to Replace a Window Arm for an Out-Swinging Casement Window: 2 단계, 이미지 3/3
    • Pull open all four metal screen latches holding the window screen in place.
    • Place hands on both sides of the screen and lift upwards to remove it.
    • In some cases only two screen latches need to be unlocked for the screen to become loose enough to remove.
  3. How to Replace a Window Arm for an Out-Swinging Casement Window: 3 단계, 이미지 1/3 How to Replace a Window Arm for an Out-Swinging Casement Window: 3 단계, 이미지 2/3 How to Replace a Window Arm for an Out-Swinging Casement Window: 3 단계, 이미지 3/3
    • Turn the window handle clockwise to open the window.
  4. How to Replace a Window Arm for an Out-Swinging Casement Window: 4 단계, 이미지 1/1
    • Use a flathead screwdriver in a clockwise direction to remove the 2.11 mm screw from the bottom of the window handle.
  5. How to Replace a Window Arm for an Out-Swinging Casement Window: 5 단계, 이미지 1/3 How to Replace a Window Arm for an Out-Swinging Casement Window: 5 단계, 이미지 2/3 How to Replace a Window Arm for an Out-Swinging Casement Window: 5 단계, 이미지 3/3
    • Turn the loosened window handle in either direction to remove it.
  6. How to Replace a Window Arm for an Out-Swinging Casement Window: 6 단계, 이미지 1/3 How to Replace a Window Arm for an Out-Swinging Casement Window: 6 단계, 이미지 2/3 How to Replace a Window Arm for an Out-Swinging Casement Window: 6 단계, 이미지 3/3
    • Detach the window arm from the track running underneath the window.
    • In most cases window arm has already been detached, so this step would be skipped.
  7. How to Replace a Window Arm for an Out-Swinging Casement Window: 7 단계, 이미지 1/3 How to Replace a Window Arm for an Out-Swinging Casement Window: 7 단계, 이미지 2/3 How to Replace a Window Arm for an Out-Swinging Casement Window: 7 단계, 이미지 3/3
    • Using a Square #0 screwdriver, remove the four 25.4 mm screws placed on the outside of the window sill.
  8. How to Replace a Window Arm for an Out-Swinging Casement Window: 8 단계, 이미지 1/3 How to Replace a Window Arm for an Out-Swinging Casement Window: 8 단계, 이미지 2/3 How to Replace a Window Arm for an Out-Swinging Casement Window: 8 단계, 이미지 3/3
    • Pull the body of the window operator which when removed will vacate a slot.
    • Pull the window arm diagonally through the slot.
  9. How to Replace a Window Arm for an Out-Swinging Casement Window: 9 단계, 이미지 1/2 How to Replace a Window Arm for an Out-Swinging Casement Window: 9 단계, 이미지 2/2
    • Insert the new window operator into the slot, ensuring it is tightly fit into place.
    • Attach a replacement window arm to the track on the bottom of the window panel.
결론
Nabil Patel
회원 가입일: 01/08/21
169 평판
안내서 1개 작성함
York University, Team S1-G21, O'Regan Winter 2021 York University, Team S1-G21, O'Regan Winter 2021 회원
YORK-O'REGAN-W21S1G21
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 27
30일 전: 126
전체 시간: 1,633
