주요 콘텐츠로 건너뛰기
How to Replace a Wooden Gate Latch
필요한 것
  1. How to Replace a Wooden Gate Latch, Gate Latch: 1 단계, 이미지 1/2 How to Replace a Wooden Gate Latch, Gate Latch: 1 단계, 이미지 2/2
    • Using a ruler and a sharpie, draw a line starting at the bottom corner of the gate to the top corner of the gate, to ensure it is parallel with the rest of the gate.
  2. How to Replace a Wooden Gate Latch: 2 단계, 이미지 1/1
    • Place a level on the gate to ensure that the gate is properly level.
  3. How to Replace a Wooden Gate Latch: 3 단계, 이미지 1/3 How to Replace a Wooden Gate Latch: 3 단계, 이미지 2/3 How to Replace a Wooden Gate Latch: 3 단계, 이미지 3/3
    • Starting at the bottom of the gate, place the power saw on the sharpie line and cut along the entirety of the line.
    • Do saw from the opposite side of the fence.
  4. How to Replace a Wooden Gate Latch: 4 단계, 이미지 1/2 How to Replace a Wooden Gate Latch: 4 단계, 이미지 2/2
    • Using a ruler, measure 6 inches down from the top of the gate and mark that spot using a sharpie.
  5. How to Replace a Wooden Gate Latch: 5 단계, 이미지 1/3 How to Replace a Wooden Gate Latch: 5 단계, 이미지 2/3 How to Replace a Wooden Gate Latch: 5 단계, 이미지 3/3
    • Using a ruler, measure 6 inches down from the top of the adjacent fence and mark the spot using a sharpie
  6. How to Replace a Wooden Gate Latch: 6 단계, 이미지 1/3 How to Replace a Wooden Gate Latch: 6 단계, 이미지 2/3 How to Replace a Wooden Gate Latch: 6 단계, 이미지 3/3
    • At the marked location on the gate, attach the latch for the gate using a power drill and screws.
  7. How to Replace a Wooden Gate Latch: 7 단계, 이미지 1/3 How to Replace a Wooden Gate Latch: 7 단계, 이미지 2/3 How to Replace a Wooden Gate Latch: 7 단계, 이미지 3/3
    • On the adjacent fence at the marked spot attach the second half of the latching mechanism using a power drill and screws.
  8. How to Replace a Wooden Gate Latch: 8 단계, 이미지 1/3 How to Replace a Wooden Gate Latch: 8 단계, 이미지 2/3 How to Replace a Wooden Gate Latch: 8 단계, 이미지 3/3
    • Sand the edge of the gate that was cut using a power sander until the edge is smooth and fits properly when closing the gate.
결론
Gracie
회원 가입일: 10/07/20
157 평판
안내서 1개 작성함
University of Memphis, Team S3-G7, Willis Fall 2020 University of Memphis, Team S3-G7, Willis Fall 2020 회원
UM-WILLIS-F20S3G7
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 33
전체 시간: 1,099
