주요 콘텐츠로 건너뛰기
How to Replace or Clean a Macbook Key
필요한 것
  1. How to Replace or Clean a Macbook Key, How to Replace or Clean a Macbook Key: 1 단계, 이미지 1개 중 1개
    • Stick your finger underneath the key. Gently pry it up.
    • You may need a spudger or flathead screwdriver to remove the key.
  2. How to Replace or Clean a Macbook Key: 2 단계, 이미지 1개 중 1개
    • Now, carefully use your spudger or small flathead to, very gently, pry up the key mechanism, being careful not to damage it.
    • You should now clean the key using a Q-tip, and taking the key and mechanism and put it in water and dry it out. It's not too hard to put the mechanism back together again. Or use a can of compressed air.
  3. How to Replace or Clean a Macbook Key: 3 단계, 이미지 1개 중 1개
    • Once you have removed and cleaned the key (or have not cleaned) take a close look at the key. There is a big hook on the right side, and two smaller hooks on the top left and bottom left.
  4. How to Replace or Clean a Macbook Key: 4 단계, 이미지 1개 중 1개
    • Now what you want to do, is hold the mechanism flat side up. Put the mechanism into the hook on the right side. A spudger or small flathead might help.
  5. How to Replace or Clean a Macbook Key: 5 단계, 이미지 1개 중 1개
    • Now pop in the two pins on the bottom left and top left into their hooks using a small spudger or flathead.
  6. How to Replace or Clean a Macbook Key: 6 단계, 이미지 1개 중 1개
    • Now, take the key cap and pop it back on the computer.
    • When you put the key back on, press it a few times to make sure the mechanism doesn't come out.
    • Now test the keyboard, verifying that everything works.
결론
That was the guide on how to clean the keys on a MacBook.
다른 18명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Brandon Sky Pimenta
회원 가입일: 09/09/12
1,383 평판
안내서 1개를 작성함
1가이드 댓글
Awesome article about mac laptop key replacement
Andrew Mac
http://www.replacementlaptopkeys.com/
James lee - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 101
지난 30일: 614
전체 시간: 76,338
