주요 콘텐츠로 건너뛰기
How to Replace the Bail Spring in a Spinning Reel
필요한 것
  1. How to Replace the Bail Spring in a Spinning Reel, Spinning Reel Bail Spring Replacement for south bend 840: 1 단계, 이미지 1/1
    • Remove the screw that holds the base of the bail arm to the reel with a Phillips #1 screwdriver.
  2. How to Replace the Bail Spring in a Spinning Reel: 2 단계, 이미지 1/2 How to Replace the Bail Spring in a Spinning Reel: 2 단계, 이미지 2/2
    • Slowly pull the base of the bail arm away from the reel in a twisting motion to separate the two parts.
  3. How to Replace the Bail Spring in a Spinning Reel: 3 단계, 이미지 1/1
    • Remove the worn out bail spring by pushing down on the spring, then pulling outward away from the reel.
  4. How to Replace the Bail Spring in a Spinning Reel: 4 단계, 이미지 1/3 How to Replace the Bail Spring in a Spinning Reel: 4 단계, 이미지 2/3 How to Replace the Bail Spring in a Spinning Reel: 4 단계, 이미지 3/3
    • Replace the worn out bail spring by separating the pin from the spring. Then place the original pin inside of the new spring.
  5. How to Replace the Bail Spring in a Spinning Reel: 5 단계, 이미지 1/2 How to Replace the Bail Spring in a Spinning Reel: 5 단계, 이미지 2/2
    • Place the new bail spring and pin back in the spring slot. Lightly push down on the spring to allow it to sit in its original position.
  6. How to Replace the Bail Spring in a Spinning Reel: 6 단계, 이미지 1/1
    • Line the bail back up with the reel, ensuring all holes align with each other. Lightly squeeze the bail and reel together to allow the two pieces to snap back together.
  7. How to Replace the Bail Spring in a Spinning Reel: 7 단계, 이미지 1/1
    • Insert the same screw used in Step 1 back into the hole and firmly screw it in.
결론
By replacing the spring, the entire open bail reel is saved from turning into unnecessary garbage that is harmful to the environment. Happy Fishing!
다른 5명이 해당 안내서를 완성하였습니다.
Zach Lyles
회원 가입일: 02/20/19
177 평판
안내서 1개 작성함
University of Memphis, Team S2-G7, Baddour Spring 2019 University of Memphis, Team S2-G7, Baddour Spring 2019 회원
UM-BADDOUR-S19S2G7
3 회원들
안내서 2개 작성하였습니다
댓글 한 개
Thanks for the clear pictures and instructions. Your tutorial was helpful along with a YouTube video on bail repair of a very similar spinning reel I have.
Steve McCormick - 답글
댓글 쓰기
조회 통계:
24 시간 전: 18
7일 전: 130
30일 전: 541
전체 시간: 32,653
