주요 콘텐츠로 건너뛰기
How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock
필요한 것
  1. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: 1 단계, 이미지 1/3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: 1 단계, 이미지 2/3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: 1 단계, 이미지 3/3
    • Remove the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
    • Left side
    • Right side
    • Bottom
  2. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 2 단계, 이미지 1/3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 2 단계, 이미지 2/3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 2 단계, 이미지 3/3
    • Remove the faceplate from the lock mechanism by pulling straight out.
  3. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 3 단계, 이미지 1/3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 3 단계, 이미지 2/3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 3 단계, 이미지 3/3
    • Remove the battery pack from the lock mechanism by pulling straight up.
  4. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 4 단계, 이미지 1/3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 4 단계, 이미지 2/3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 4 단계, 이미지 3/3
    • Remove the batteries from the battery pack.
  5. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 5 단계, 이미지 1/3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 5 단계, 이미지 2/3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 5 단계, 이미지 3/3
    • Insert new batteries into the battery pack.
  6. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 6 단계, 이미지 1/3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 6 단계, 이미지 2/3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 6 단계, 이미지 3/3
    • Insert the battery pack back into the lock mechanism by pushing straight down.
    • Make sure the label is facing outward.
  7. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 7 단계, 이미지 1/3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 7 단계, 이미지 2/3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 7 단계, 이미지 3/3
    • Reattach the faceplate to the lock mechanism by pushing straight in.
  8. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 8 단계, 이미지 1/3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 8 단계, 이미지 2/3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 8 단계, 이미지 3/3
    • Reattach the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
    • Bottom
    • Right side
    • Left side
결론
That's it! Your Kwikset Home Connect 620 Smart Lock should now be working properly.
Lis Cinelli
회원 가입일: 09/28/20
376 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 61
전체 시간: 203
