주요 콘텐츠로 건너뛰기
How to Replace the Battery from an Armitron All-Sport Watch
필요한 것
  1. How to Replace the Battery from an Armitron All-Sport Watch, Battery: 1 단계, 이미지 1/2 How to Replace the Battery from an Armitron All-Sport Watch, Battery: 1 단계, 이미지 2/2
    • Remove the back strap.
    • Remove four 1.7 mm Phillips Pan Head screws.
  2. How to Replace the Battery from an Armitron All-Sport Watch: 2 단계, 이미지 1/2 How to Replace the Battery from an Armitron All-Sport Watch: 2 단계, 이미지 2/2
    • Pull back on the strap, while keeping a finger pressed to the metal covering.
    • Gently pull away the metal covering away from the watch.
  3. How to Replace the Battery from an Armitron All-Sport Watch: 3 단계, 이미지 1/3 How to Replace the Battery from an Armitron All-Sport Watch: 3 단계, 이미지 2/3 How to Replace the Battery from an Armitron All-Sport Watch: 3 단계, 이미지 3/3
    • Pinch the metal tab.
    • Pull the chip up and out.
  4. How to Replace the Battery from an Armitron All-Sport Watch: 4 단계, 이미지 1/1
    • Remove two 1.5 mm Phillips Pan Head screws.
  5. How to Replace the Battery from an Armitron All-Sport Watch: 5 단계, 이미지 1/1
    • Remove the battery.
    • Take note of the orientation the battery is in for proper replacement.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Jose Cabrera
회원 가입일: 02/23/15
452 평판
안내서 1개 작성함
Cal Poly, Team 12-2, Green Winter 2015 Cal Poly, Team 12-2, Green Winter 2015 회원
CPSU-GREEN-W15S12G2
6 회원들
안내서 13개 작성하였습니다
댓글 9개
what about the after battery replacement short circuit to reset it? that’s the hard part that totally is unclear!
holograf00 - 답글
With a magnifying glass there is RESET written with a small diamond [THE ARROW] at one part of the back under the battery, On the side there is a slot that you put a piece of flat metal, small tipped screwdriver, into it. This will touch the contacts inside to reset the watch.
Greg Scott -
what about the post battery replacement short circuit reset?! that’s the hard part that’s completely unclear and confusing!
holograf00 - 답글
my comments don’t seem to be working.
holograf00 - 답글
I agree that these instructions are very deficient when describing how to reset the battery. I just spent 1/2 hour resetting an Amitron MD0699. One is supposed to bridge about a 2 mm gap between 2 vertical bands of metal. The space to approach this is very small. A normal paper clip tip is too narrow for this purpose. A large metallic paper clip tip might work, but you will have to prove that the metal is conductive. My micro screwdriver set didn’t work; I didn’t realize the metal was non conductive til I tested it with an electrometer. In the end, the electrometer tip was just the right size. I reassuring little chime rang when the reset occurs. All these little fine points would have made the original post useful.
pkenny - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 56
30일 전: 304
전체 시간: 68,113
