주요 콘텐츠로 건너뛰기
How to Replace the Bearings on a Street Skateboard
필요한 것
  1. How to Replace the Bearings on a Street Skateboard, Bearings: 1 단계, 이미지 1개 중 1개
    • Lay the skateboard on its side so that bearings and axles are facing toward you.
  2. How to Replace the Bearings on a Street Skateboard: 2 단계, 이미지 3개 중 1개 How to Replace the Bearings on a Street Skateboard: 2 단계, 이미지 3개 중 2개 How to Replace the Bearings on a Street Skateboard: 2 단계, 이미지 3개 중 3개
    • Using a skateboard tool or wrench, unscrew the axle nut above the wheel.
    • Remove the wheel from the axle.
  3. How to Replace the Bearings on a Street Skateboard: 3 단계, 이미지 3개 중 1개 How to Replace the Bearings on a Street Skateboard: 3 단계, 이미지 3개 중 2개 How to Replace the Bearings on a Street Skateboard: 3 단계, 이미지 3개 중 3개
    • Position the wheel halfway on the end of the axle.
    • Holding the skateboard down with your other hand, use the end of the axle to pry the bearing out.
  4. How to Replace the Bearings on a Street Skateboard: 4 단계, 이미지 2개 중 1개 How to Replace the Bearings on a Street Skateboard: 4 단계, 이미지 2개 중 2개
    • Set the old bearing aside.
    • Repeat the previous step with the other side of the wheel to remove the other bearing.
  5. How to Replace the Bearings on a Street Skateboard: 5 단계, 이미지 3개 중 1개 How to Replace the Bearings on a Street Skateboard: 5 단계, 이미지 3개 중 2개 How to Replace the Bearings on a Street Skateboard: 5 단계, 이미지 3개 중 3개
    • Place a fresh bearing face down (colored side down) onto the axle, and push the wheel down against the metal truck to pop the new bearing in.
    • Hold the skateboard in place with your other hand.
  6. How to Replace the Bearings on a Street Skateboard: 6 단계, 이미지 1개 중 1개
    • Take the wheel off.
    • Add another fresh bearing onto the axle.
    • Repeat the previous step for the other side of the wheel by pushing the wheel down to pop the bearing in.
  7. How to Replace the Bearings on a Street Skateboard: 7 단계, 이미지 3개 중 1개 How to Replace the Bearings on a Street Skateboard: 7 단계, 이미지 3개 중 2개 How to Replace the Bearings on a Street Skateboard: 7 단계, 이미지 3개 중 3개
    • Place washer(s) onto the axle and then screw the axle nut back on.
    • Repeat steps as needed with other wheels.
결승점
작성자
3다른 기여자 명과 함께
Maxen Hamelynck
회원 가입일: 01/21/25
157 평판
안내서 1개를 작성함
UC Davis, Team 1-4, Morris Winter 2025 UC Davis, Team 1-4, Morris Winter 2025 회원
UCD-MORRIS-W25S1G4
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 96
