이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the old cork.
Insert a sharp tool, such as one tine of a pair of tweezers or needle-nose forceps, between the cork and the metal edge.
Pry up the cork using the metal edge for leverage.
Repeat this at several points around the cork until the cork comes free.
If you have a replacement cork, skip to Step 10.
If you’re using a wine bottle cork to make a replacement cork, place the cork on its side and measure 3 mm from the cork edge. Mark this point.
Using a serrated knife (such as a steak knife), cut the cork horizontally along your mark.
Using a ruler, measure the diameter of the water key slot you removed the cork from in Step 2.
Place the 3mm slice you cut from the wine cork flat on a surface.
Mark a point in the center.
Using a ruler, measure half the diameter from Step 5 above and below the center mark.
Rotate the ruler 90 degrees and repeat Step 7.
Draw a circle connecting the four marks around the center.
Using your knife, cut out this circle.
This might take a few tries, so if you end up with a non-round circle cut out, repeat Steps 3-9 with the remaining wine cork.
Dry fit the new cork in the water key slot to make sure it is the right size.
If your cork is too big, you'll need to cut it a little smaller.
If your cork is a little uneven, don't worry. Its job is to seal the water hole, which is much smaller than the cork itself.
With a hot glue gun, put a drop of glue in the water key slot and place the new cork on top.
Press firmly on the cork for a few seconds.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 한 개
Let me suggest that there is an easier way to a permanent solution for leaky corks - remove the water automatically by installing a JoyKey. No more leaking corks, no moving parts, no sptings or having to manually deal with water.
For more information:
www.thejoykey.com and http://thejoykey.com/wp-content/uploads/...
