소개
Has your stereo blown out one or both of your tweeters? Use this guide to help you replace them.
필요한 것
Take your flat head screwdriver and gently pry off the plastic grille covering your tweeter.
There are 4 clips holding the grille down, 1 in each corner. Be careful not to break them.
You have succesfully replaced your tweeter. Follow the same steps to do the other side and test your stereo to make sure they are installed properly.
다른 4명이 해당 안내서를 완성하였습니다.
