소개
The purpose of this technical description is to explore the Utilitech SFC1-500B 20” High Velocity Floor Fan at the system-level, then discuss the important parts directly related to using the device. This description will give the user a basic idea of fan’s design and operation so as to become more proficient in its use.
필요한 것
다른 2명이 해당 안내서를 완성하였습니다.
댓글 6개
do you have the wiring schematics for this fan my wire broke from the copper coil thank you
My Ulitiech fan suddenly stopped working. What can I do to get it to work again. Or is it my new door stop?
My cord on my utilitech floor fan was severed by my table saw and I’ve spliced the cord and it still won’t work. Could there be a reset button or something I’m missing?
Steve Case - 답글
You title this on how to remove the fan blades then don't actually show how to remove the fan blades but get the whole motor with the fan blades attached.
