주요 콘텐츠로 건너뛰기
How to Replace the GE Refrigerator Ice Dispenser Solenoid SN:GSL25IGXL LS
필요한 것
  1. How to Replace the GE Refrigerator Ice Dispenser Solenoid SN:GSL25IGXL LS, Ice Dispenser Solenoid: 1 단계, 이미지 1/1
    • Turn off all power to the refrigerator before disassembling.
    • Unplug the refrigerator to turn off the power. You can also turn off the power using the breaker panel.
  2. How to Replace the GE Refrigerator Ice Dispenser Solenoid SN:GSL25IGXL LS: 2 단계, 이미지 1/1
    • First, remove the plastic trim. It is held in by six clips; you can use a pry tool or your hands.
  3. How to Replace the GE Refrigerator Ice Dispenser Solenoid SN:GSL25IGXL LS: 3 단계, 이미지 1/1
    • Remove the dispenser interface by pushing up, then pulling the bottom out.
    • This will reveal the wire harnesses that will be disconnected in the next step.
  4. How to Replace the GE Refrigerator Ice Dispenser Solenoid SN:GSL25IGXL LS: 4 단계, 이미지 1/1
    • Disconnect the three wire harnesses.
    • They might be tight, so be careful when pulling on them.
    • Once the wires are disconnected, set the interface aside.
  5. How to Replace the GE Refrigerator Ice Dispenser Solenoid SN:GSL25IGXL LS: 5 단계, 이미지 1/1
    • Remove the four 3.8mm screws in each corner using a Phillips #0 screwdriver and remove the housing.
    • Once it is removed, the solenoid will be exposed.
  6. How to Replace the GE Refrigerator Ice Dispenser Solenoid SN:GSL25IGXL LS: 6 단계, 이미지 1/1
    • Remove the bottom two 2.5mm Phillips screws first.
    • Loosen the top Phillips screw and remove the solenoid.
    • After this step is complete, replace the old solenoid and reassemble following the steps in reverse order.
결론
John E McKee
회원 가입일: 03/28/20
133 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 35
전체 시간: 1,902
