주요 콘텐츠로 건너뛰기
How to Replace the GPU on a Dell OptiPlex 9010
필요한 것
  1. How to Replace the GPU on a Dell OptiPlex 9010, Graphics Card: 1 단계, 이미지 1/3 How to Replace the GPU on a Dell OptiPlex 9010, Graphics Card: 1 단계, 이미지 2/3 How to Replace the GPU on a Dell OptiPlex 9010, Graphics Card: 1 단계, 이미지 3/3
    • Before getting started, make sure to shut down and unplug all cables from your computer.
    • Place the computer on a flat surface.
  2. How to Replace the GPU on a Dell OptiPlex 9010: 2 단계, 이미지 1/2 How to Replace the GPU on a Dell OptiPlex 9010: 2 단계, 이미지 2/2
    • Lay the computer on its side, on the flat surface.
    • Use a Phillips #2 screwdriver to remove any screws holding the side panel in place.
    • Use the handle on the side panel to pull it up to remove it.
  3. How to Replace the GPU on a Dell OptiPlex 9010: 3 단계, 이미지 1/3 How to Replace the GPU on a Dell OptiPlex 9010: 3 단계, 이미지 2/3 How to Replace the GPU on a Dell OptiPlex 9010: 3 단계, 이미지 3/3
    • Grip the side panel with both hands to fully remove it. This will give you a complete look into the internal hardware.
    • Be sure to touch the metal casing inside to ground yourself. Otherwise, you might accidentally damage the components from the static electricity your body builds up.
  4. How to Replace the GPU on a Dell OptiPlex 9010: 4 단계, 이미지 1/3 How to Replace the GPU on a Dell OptiPlex 9010: 4 단계, 이미지 2/3 How to Replace the GPU on a Dell OptiPlex 9010: 4 단계, 이미지 3/3
    • Push down on the release tab on the card retention latch to free the existing (old) graphics card.
  5. How to Replace the GPU on a Dell OptiPlex 9010: 5 단계, 이미지 1/3 How to Replace the GPU on a Dell OptiPlex 9010: 5 단계, 이미지 2/3 How to Replace the GPU on a Dell OptiPlex 9010: 5 단계, 이미지 3/3
    • Unlatch the PCIE clip. Gently remove the existing graphics card to make sure there are no cables caught.
  6. How to Replace the GPU on a Dell OptiPlex 9010: 6 단계, 이미지 1/3 How to Replace the GPU on a Dell OptiPlex 9010: 6 단계, 이미지 2/3 How to Replace the GPU on a Dell OptiPlex 9010: 6 단계, 이미지 3/3
    • Now grab your replacement GPU (graphics card).
  7. How to Replace the GPU on a Dell OptiPlex 9010: 7 단계, 이미지 1/3 How to Replace the GPU on a Dell OptiPlex 9010: 7 단계, 이미지 2/3 How to Replace the GPU on a Dell OptiPlex 9010: 7 단계, 이미지 3/3
    • Add or remove expansion slot covers based on the number of slots your new graphics card requires.
  8. How to Replace the GPU on a Dell OptiPlex 9010: 8 단계, 이미지 1/2 How to Replace the GPU on a Dell OptiPlex 9010: 8 단계, 이미지 2/2
    • Firmly place the new GPU on the bus (into the slot). Reclip the PCIE clamp to hold it into place.
  9. How to Replace the GPU on a Dell OptiPlex 9010: 9 단계, 이미지 1/3 How to Replace the GPU on a Dell OptiPlex 9010: 9 단계, 이미지 2/3 How to Replace the GPU on a Dell OptiPlex 9010: 9 단계, 이미지 3/3
    • Check to make sure the new GPU card is properly positioned to fit with the screw holes and expansion slots.
  10. How to Replace the GPU on a Dell OptiPlex 9010: 10 단계, 이미지 1/2 How to Replace the GPU on a Dell OptiPlex 9010: 10 단계, 이미지 2/2
    • Screw in any 6-32 Phillips screws (any that are from 1/4 to 1/2 inch long) with your Phillips screwdriver to properly secure your new GPU card.
  11. How to Replace the GPU on a Dell OptiPlex 9010: 11 단계, 이미지 1/3 How to Replace the GPU on a Dell OptiPlex 9010: 11 단계, 이미지 2/3 How to Replace the GPU on a Dell OptiPlex 9010: 11 단계, 이미지 3/3
    • Pull up on the release tab on the card retention latch to secure the card.
  12. How to Replace the GPU on a Dell OptiPlex 9010: 12 단계, 이미지 1/2 How to Replace the GPU on a Dell OptiPlex 9010: 12 단계, 이미지 2/2
    • Line the side panel up with the clamps and push it down to reattach the panel.
  13. How to Replace the GPU on a Dell OptiPlex 9010: 13 단계, 이미지 1/2 How to Replace the GPU on a Dell OptiPlex 9010: 13 단계, 이미지 2/2
    • Use your Phillips #2 screwdriver to replace the screws and secure the side panel.
결승점
Michael Cortez
회원 가입일: 09/19/22
217 평판
안내서 1개 작성함
York University, Team A-10, Morris Fall 2022 York University, Team A-10, Morris Fall 2022 회원
YORK-MORRIS-F22SAG10
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 33
전체 시간: 761
