소개
Is your Dell OptiPlex 9010 system having issues like visual glitches on the screen, crashing and blue screens? It may be time to replace your graphics card. This component is responsible for handling graphics related work like effects and videos.
It's a relatively easy fix, but be sure to ground yourself by touching the computer's metal casing to protect the components from static. As long as you ground yourself this way, the installation won't require any special skills, and your computer will be running smoothly.
필요한 것
Before getting started, make sure to shut down and unplug all cables from your computer.
Place the computer on a flat surface.
Grip the side panel with both hands to fully remove it. This will give you a complete look into the internal hardware.
Once this is done, be sure to touch the metal casing inside to ground yourself. Otherwise, you might accidentally damage the components from the static electricity your body builds up.
