주요 콘텐츠로 건너뛰기
How to Replace the Handle on a KitchenArt Nonstick Pot
필요한 것
  1. How to Replace the Handle on a KitchenArt Nonstick Pot, How to Replace the Handle on a KitchenArt Nonstick Pot: 1 단계, 이미지 1/1
    • Clean the components.
  2. How to Replace the Handle on a KitchenArt Nonstick Pot: 2 단계, 이미지 1/3 How to Replace the Handle on a KitchenArt Nonstick Pot: 2 단계, 이미지 2/3 How to Replace the Handle on a KitchenArt Nonstick Pot: 2 단계, 이미지 3/3
    • Insert the screw through the center of the smaller steel bracket.
  3. How to Replace the Handle on a KitchenArt Nonstick Pot: 3 단계, 이미지 1/2 How to Replace the Handle on a KitchenArt Nonstick Pot: 3 단계, 이미지 2/2
    • Line up the pegs of the handle with the holes in the larger iron bracket.
  4. How to Replace the Handle on a KitchenArt Nonstick Pot: 4 단계, 이미지 1/3 How to Replace the Handle on a KitchenArt Nonstick Pot: 4 단계, 이미지 2/3 How to Replace the Handle on a KitchenArt Nonstick Pot: 4 단계, 이미지 3/3
    • Insert the screw with the smaller iron sheet from inside of the lid to outside of the lid
  5. How to Replace the Handle on a KitchenArt Nonstick Pot: 5 단계, 이미지 1/1
    • Insert the screw into the screw hole in the lid.
  6. How to Replace the Handle on a KitchenArt Nonstick Pot: 6 단계, 이미지 1/3 How to Replace the Handle on a KitchenArt Nonstick Pot: 6 단계, 이미지 2/3 How to Replace the Handle on a KitchenArt Nonstick Pot: 6 단계, 이미지 3/3
    • Slightly turn over the lid to make yourself face to inside of the lid
  7. How to Replace the Handle on a KitchenArt Nonstick Pot: 7 단계, 이미지 1/3 How to Replace the Handle on a KitchenArt Nonstick Pot: 7 단계, 이미지 2/3 How to Replace the Handle on a KitchenArt Nonstick Pot: 7 단계, 이미지 3/3
    • Use a screwdriver to tighten the screw.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Zijing Wang
회원 가입일: 01/11/23
169 평판
안내서 1개 작성함
York University, Team O-29, Woodhouse Winter 2023 York University, Team O-29, Woodhouse Winter 2023 회원
YORK-WOODHOUSE-W23SOG29
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 24
전체 시간: 277
