소개
This guide will help you replace a malfunctioning heater in your dishwasher, a common issue that affects cleaning efficiency and water heating. Replacing the heater is crucial as it cannot be repaired. This task demands caution due to sharp edges and limited access inside the dishwasher.
필요한 것
2 단계 Access the visible heater on older models
Remove the front decorative panel by unscrewing the four screws.
3 단계 Detach heater brackets and check components
Unscrew the heater's brackets using a wrench on the nut, typically size 8.
4 단계 Disconnect electrical connections
Take a Picture: Before disconnecting anything, take a picture of the wiring for reference during reassembly.
Use a wrench to loosen and remove the nuts securing the heating element terminals. Carefully disconnect the electrical connectors from the heating element.
Unscrew the screw that holds the heater clamped to the cabinet.
5 단계 Remove and replace the heater
Locate the heating element, usually a U-shaped metal tube at the bottom, remove the heater from the dishwasher and take it to a store to match a new one visually.
Install the new heater by reversing the removal process.
6 단계 Reconnect electrical wires
Reconnect the wires, ensuring the grounding wire is attached to the external conductive part.
7 단계 Reassemble the heater brackets
Reattach the heater brackets and ensure the gasket is correctly positioned.
Reattach the bottom access panel and secure it with screws.
Slide the lower dish rack back into place inside the dishwasher.
8 단계 Test for leaks
Turn the water supply back on.
Run a short wash cycle to ensure the heating element works properly. Check for leaks or loose connections under the dishwasher.
If everything is functioning correctly, the replacement is complete.
9 단계 Access hidden heater on mid-range models
Acces the hidden hetaer at the back of the dishwasher.
If there is a protective cover over the heating element inside the tub, remove the screws and detach it.
10 단계 Disconnect electrical connections
Locate the heating element connections at the back of the dishwasher.
Take a Picture: Before disconnecting anything, take a photo of the wiring for easy reassembly.
Use a wrench to remove the nuts securing the heating element terminals. Gently disconnect the electrical connectors.
11 단계 Remove and replace the hidden heater
Inside the dishwasher, release the heating element from its mounting brackets.
Guide the terminals carefully through the holes at the back of the dishwasher while pulling out the element.
Insert the new heating element, making sure its terminals go through the designated holes.
Secure the heating element with the mounting brackets inside the dishwasher.
12 단계 Reconnect the wires
Under the dishwasher, reconnect the electrical wires and tighten the securing nuts with a wrench.
13 단계 Reattach plastic components
Reinstall the plastic clips and panels as they were originally placed.
14 단계 Access flow-through heater on modern models
Access the flow-through heater at the bottom of the dishwasher.
15 단계 Disconnect and remove flow-through heater
Take a Picture: Before disconnecting, take a photo of the wiring and hose connections for reference.
Remove the plastic cover secured with small screws to expose the flow-through heater.
Loosen the clamp and disconnect the heater from its position. Use pliers to remove the hose clamps securing the water inlet and outlet hoses.
Use a wrench to remove the nuts securing the electrical connectors, then disconnect the wires.
16 단계 Replace flow-through heater
Remove the heater and replace it with a new one following the same orientation.
Use lubrication and pliers for an easier assembly.
17 단계 Secure the new heater
Reattach the clamp ensuring the heater is tightly secured in place.
Reattach the bottom access panel (kickplate) with screws.
18 단계 Final reassembly
Reinstall any remaining components and ensure everything is secured properly.
Push the dishwasher back into place.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
