주요 콘텐츠로 건너뛰기
How to Replace the Lightbulbs in a Whirlpool WMH31017HB
필요한 것
  1. How to Replace the Lightbulbs in a Whirlpool WMH31017HB, Lightbulbs: 1 단계, 이미지 1개 중 1개
    • Ensure the underside of the hood is clean, and that there is no oil on it.
    • To remove built-up grease, you can use dish soap and a sponge.
    • Make sure there is no food on the stove.
    • Have the range hood lights on, as you need to be able to see everything.
  2. How to Replace the Lightbulbs in a Whirlpool WMH31017HB: 2 단계, 이미지 1개 중 1개
    • Gently unscrew and open the hood panel that is covering the lights with a screwdriver.
  3. How to Replace the Lightbulbs in a Whirlpool WMH31017HB: 3 단계, 이미지 1개 중 1개
    • Slowly pull down the lid of the light box.
    • Beware of any shattered light bulbs. To be safe, place a newspaper or a towel under, on the stove. As this catches all the glass and prevents any injuries.
  4. How to Replace the Lightbulbs in a Whirlpool WMH31017HB: 4 단계, 이미지 2개 중 1개 How to Replace the Lightbulbs in a Whirlpool WMH31017HB: 4 단계, 이미지 2개 중 2개
    • Turn the lights off.
    • Wait to ensure the lightbulb is cooled down.
    • Do not touch the lightbulb as soon as you have turned it off; it is extremely hot.
  5. How to Replace the Lightbulbs in a Whirlpool WMH31017HB: 5 단계, 이미지 1개 중 1개
    • Use a towel to unscrew the light bulbs clockwise from inside the hood or if it is cooled down completely you can use your bare hands.
    • If the bulb has been shattered, ensure that you are twisting the remaining parts carefully. Watch for sharp ends.
  6. How to Replace the Lightbulbs in a Whirlpool WMH31017HB: 6 단계, 이미지 1개 중 1개
    • Check the information on the needed light bulb, then purchase a new one. The bulb is 40 W.
    • Often there is a sticker attached to the bulb with the information.
  7. How to Replace the Lightbulbs in a Whirlpool WMH31017HB: 7 단계, 이미지 2개 중 1개 How to Replace the Lightbulbs in a Whirlpool WMH31017HB: 7 단계, 이미지 2개 중 2개
    • Insert the new lightbulb back and turn it to tighten it.
결론
Close the lid and screw with the screwdriver again.
작성자
3다른 기여자 명과 함께
Shina Salehi
회원 가입일: 01/14/23
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 27
지난 30일: 87
전체 시간: 1,963
