주요 콘텐츠로 건너뛰기
How to Replace the Net on a Basketball Hoop
필요한 것
  1. How to Replace the Net on a Basketball Hoop, Net: 1 단계, 이미지 1개 중 1개
    • Set up a ladder below the basketball rim.
    • Make sure the ladder is steady and placed on a level surface.
  2. How to Replace the Net on a Basketball Hoop: 2 단계, 이미지 3개 중 1개 How to Replace the Net on a Basketball Hoop: 2 단계, 이미지 3개 중 2개 How to Replace the Net on a Basketball Hoop: 2 단계, 이미지 3개 중 3개
    • Loop the first net loop through the basketball rim.
    • Push the net through each loop on the basketball rim.
    • Pull the net loop down and spread the rope across the rim coil as shown
    • Pull the net tightly to the rim.
  3. How to Replace the Net on a Basketball Hoop: 3 단계, 이미지 1개 중 1개
    • Using the same technique from step 2, loop the remaining net loops around the rim.
  4. How to Replace the Net on a Basketball Hoop: 4 단계, 이미지 1개 중 1개
    • Test the net and remove any wrinkles by pulling down on the bottom of the net.
  5. How to Replace the Net on a Basketball Hoop: 5 단계, 이미지 1개 중 1개
    • Step down from the ladder and play ball.
결론
Now that you've replaced your net, you're ready play some basketball.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Kevin A Walker
회원 가입일: 02/24/15
164 평판
안내서 1개를 작성함
Cal Poly, Team 23-3, Green Winter 2015 Cal Poly, Team 23-3, Green Winter 2015 회원
CPSU-GREEN-W15S23G3
6 회원들
안내서 13개를 작성함
3가이드 댓글
Thanks for letting my grandchildren help me from the Basketball Net. Your truly Kelly
akiborja1017 - 답글
i don't have these things were I can like put the net in
leon reichert - 답글
do you mean they dont have the little hooks that the net latches on to onto the hoop?
tayola -
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 66
지난 30일: 254
전체 시간: 119,865
