주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
If you have an old basketball net that needs replacing, check out this guide!
도구
지정된 도구가 없습니다.
부품
  1. Set up a ladder below the basketball rim.
    • Set up a ladder below the basketball rim.
    • Make sure the ladder is steady and placed on a level surface.
  2. Loop the first net loop through the basketball rim. Push the net through each loop on the basketball rim. Pull the net loop down and spread the rope across the rim coil as shown
    • Loop the first net loop through the basketball rim.
    • Push the net through each loop on the basketball rim.
    • Pull the net loop down and spread the rope across the rim coil as shown
    • Pull the net tightly to the rim.
  3. Using the same technique from step 2, loop the remaining net loops around the rim.
    • Using the same technique from step 2, loop the remaining net loops around the rim.
  4. Test the net and remove any wrinkles by pulling down on the bottom of the net.
    • Test the net and remove any wrinkles by pulling down on the bottom of the net.
  5. Step down from the ladder and play ball.
    • Step down from the ladder and play ball.
결론
Now that you've replaced your net, you're ready play some basketball.
다른 3명이 해당 안내서를 완성하였습니다.
Kevin A Walker
회원 가입일: 2015년 02월 24일
164 평판
안내서 1개 작성함
Cal Poly, Team 23-3, Green Winter 2015 Cal Poly, Team 23-3, Green Winter 2015 회원
CPSU-GREEN-W15S23G3
6 회원들
안내서 13개 작성하였습니다
Thanks for letting my grandchildren help me from the Basketball Net. Your truly Kelly
akiborja1017 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 29
7일 전: 249
30일 전: 1,050
전체 시간: 84,581
