주요 콘텐츠로 건너뛰기
How to Replace the Net on a Basketball Hoop
필요한 것
  1. How to Replace the Net on a Basketball Hoop, Net: 1 단계, 이미지 1/1
    • Set up a ladder below the basketball rim.
    • Make sure the ladder is steady and placed on a level surface.
  2. How to Replace the Net on a Basketball Hoop: 2 단계, 이미지 1/3 How to Replace the Net on a Basketball Hoop: 2 단계, 이미지 2/3 How to Replace the Net on a Basketball Hoop: 2 단계, 이미지 3/3
    • Loop the first net loop through the basketball rim.
    • Push the net through each loop on the basketball rim.
    • Pull the net loop down and spread the rope across the rim coil as shown
    • Pull the net tightly to the rim.
  3. How to Replace the Net on a Basketball Hoop: 3 단계, 이미지 1/1
    • Using the same technique from step 2, loop the remaining net loops around the rim.
  4. How to Replace the Net on a Basketball Hoop: 4 단계, 이미지 1/1
    • Test the net and remove any wrinkles by pulling down on the bottom of the net.
  5. How to Replace the Net on a Basketball Hoop: 5 단계, 이미지 1/1
    • Step down from the ladder and play ball.
    Come si fa quando i canestri non hanno gli occhielli a spirale, ma sono degli anelli chiusi?
    Seric - 답글
결론
Now that you've replaced your net, you're ready play some basketball.
다른 3명이 해당 안내서를 완성하였습니다.
Kevin A Walker
회원 가입일: 02/24/15
164 평판
안내서 1개 작성함
Cal Poly, Team 23-3, Green Winter 2015 Cal Poly, Team 23-3, Green Winter 2015 회원
CPSU-GREEN-W15S23G3
6 회원들
안내서 13개 작성하였습니다
댓글 3개
Thanks for letting my grandchildren help me from the Basketball Net. Your truly Kelly
akiborja1017 - 답글
i don't have these things were I can like put the net in
leon reichert - 답글
do you mean they dont have the little hooks that the net latches on to onto the hoop?
tayola -
댓글 쓰기
조회 통계:
24 시간 전: 27
7일 전: 227
30일 전: 904
전체 시간: 109,008
