이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Loop the first net loop through the basketball rim.
Push the net through each loop on the basketball rim.
Pull the net loop down and spread the rope across the rim coil as shown
Pull the net tightly to the rim.
Using the same technique from step 2, loop the remaining net loops around the rim.
Test the net and remove any wrinkles by pulling down on the bottom of the net.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 3개
Thanks for letting my grandchildren help me from the Basketball Net. Your truly Kelly
i don't have these things were I can like put the net in
do you mean they dont have the little hooks that the net latches on to onto the hoop?
tayola -
