주요 콘텐츠로 건너뛰기
How to Replace the Pom Pom on a Beanie
필요한 것
  1. How to Replace the Pom Pom on a Beanie, Beanie Pom Pom: 1 단계, 이미지 1개 중 1개
    • Use sewing scissors to cut the string that attaches the pom pom to the beanie if it's still loosely attached.
  2. How to Replace the Pom Pom on a Beanie: 2 단계, 이미지 2개 중 1개 How to Replace the Pom Pom on a Beanie: 2 단계, 이미지 2개 중 2개
    • Measure 10 inches of yarn.
    • Use your scissors to cut the yarn.
  3. How to Replace the Pom Pom on a Beanie: 3 단계, 이미지 3개 중 1개 How to Replace the Pom Pom on a Beanie: 3 단계, 이미지 3개 중 2개 How to Replace the Pom Pom on a Beanie: 3 단계, 이미지 3개 중 3개
    • Pull one end of the yarn through the eye of a hand sewing needle until you have an even amount of yarn on both sides of the needle.
    • The point of the needle is sharp enough to pierce skin.
  4. How to Replace the Pom Pom on a Beanie: 4 단계, 이미지 3개 중 1개 How to Replace the Pom Pom on a Beanie: 4 단계, 이미지 3개 중 2개 How to Replace the Pom Pom on a Beanie: 4 단계, 이미지 3개 중 3개
    • Push the needle through the pom pom, leaving a 3 inch tail of yarn.
    • Be aware of where the needle will exit and where your hand is holding the pom pom.
  5. How to Replace the Pom Pom on a Beanie: 5 단계, 이미지 3개 중 1개 How to Replace the Pom Pom on a Beanie: 5 단계, 이미지 3개 중 2개 How to Replace the Pom Pom on a Beanie: 5 단계, 이미지 3개 중 3개
    • Poke the pom pom with the point of the needle at the same place you poked it in Step 4.
    • Pull the needle all the way through and keep the yarn on the needle.
    • You will end up with two strands of yarn, one on each side of the pom pom.
  6. How to Replace the Pom Pom on a Beanie: 6 단계, 이미지 3개 중 1개 How to Replace the Pom Pom on a Beanie: 6 단계, 이미지 3개 중 2개 How to Replace the Pom Pom on a Beanie: 6 단계, 이미지 3개 중 3개
    • Push the needle through the top of the beanie.
    • Pull the needle all the way through until the pom pom is fixed against the beanie.
  7. How to Replace the Pom Pom on a Beanie: 7 단계, 이미지 3개 중 1개 How to Replace the Pom Pom on a Beanie: 7 단계, 이미지 3개 중 2개 How to Replace the Pom Pom on a Beanie: 7 단계, 이미지 3개 중 3개
    • Push the needle all the way through one of the holes of the button.
    • Keep button in place and remove the needle from the yarn.
  8. How to Replace the Pom Pom on a Beanie: 8 단계, 이미지 3개 중 1개 How to Replace the Pom Pom on a Beanie: 8 단계, 이미지 3개 중 2개 How to Replace the Pom Pom on a Beanie: 8 단계, 이미지 3개 중 3개
    • Put the second strand of yarn through the eye of the needle.
    • Poke the needle through the top of the beanie again.
    • Pull the remaining yarn all the way through to the other side of the beanie.
  9. How to Replace the Pom Pom on a Beanie: 9 단계, 이미지 3개 중 1개 How to Replace the Pom Pom on a Beanie: 9 단계, 이미지 3개 중 2개 How to Replace the Pom Pom on a Beanie: 9 단계, 이미지 3개 중 3개
    • Pull the yarn all the way through another hole in the button.
  10. How to Replace the Pom Pom on a Beanie: 11 단계, 이미지 2개 중 1개 How to Replace the Pom Pom on a Beanie: 11 단계, 이미지 2개 중 2개
    • Tie another overhand knot.
  11. How to Replace the Pom Pom on a Beanie: 12 단계, 이미지 2개 중 1개 How to Replace the Pom Pom on a Beanie: 12 단계, 이미지 2개 중 2개
    • Cut off the remaining ends of the yarn, cutting close to the button.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Erin Shea
회원 가입일: 01/26/23
259 평판
안내서 1개를 작성함
UC Davis, Team 2-4, Morris Winter 2023 UC Davis, Team 2-4, Morris Winter 2023 회원
UCD-MORRIS-W23S2G4
2 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 78
지난 30일: 338
전체 시간: 4,218
