소개
If you need to replace the propane tank in your Toyota Forklift Truck (Model: 8FGCU15), follow this guide.
This style of forklift is quite common in warehouses, and the gas tanks frequently run dry. This is an OSHA compliant step by step guide to safely replace an empty propane tank.
While changing the tank, you will need to wear the the appropriate Personal Protective Equipment (PPE). Please be sure to acquire a pair of goggles and a pair of propane resistant gloves before beginning this project.
Put the shifter in neutral, turn the engine off, and engage the emergency brake.
If done properly, there should be no drips or hissing, and little to no smell of propane. The engine should start at once.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Step 11a rotate the tank so the pin and small round hole align (facing downward). The pressure relief valve must face upwards.
In case of exposure to high heat or flame the pressure relief valve will release excessive pressure.
