소개
This guide details the process to replace the rear wheel of a Segway Ninebot ES4. Having tires with good grip is vital for safe use, so it is necessary to replace the wheels on scooters when they are worn.
필요한 것
Place the scooter on its side and locate the two access screw holes.
Use a flathead screwdriver to remove the protective inserts.
With that, you've replaced the rear wheel of your Segway Ninebot ES4! Happy scootering!
다른 한 분이 해당 안내서를 완성하였습니다.
