주요 콘텐츠로 건너뛰기
How to Replace the Suction Cups for the Anti-Clamp
  1. How to Replace the Suction Cups for the Anti-Clamp, Suction cup information: 1 단계, 이미지 2개 중 1개 How to Replace the Suction Cups for the Anti-Clamp, Suction cup information: 1 단계, 이미지 2개 중 2개
    • The suction cups are secured to the clamp by friction-fit pins.
    • To remove the pins, you have to push them through their indents in the clamp's arms.
  2. How to Replace the Suction Cups for the Anti-Clamp, Remove the suction cups: 2 단계, 이미지 3개 중 1개 How to Replace the Suction Cups for the Anti-Clamp, Remove the suction cups: 2 단계, 이미지 3개 중 2개 How to Replace the Suction Cups for the Anti-Clamp, Remove the suction cups: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Clampy - Anti-Clamp
    $24.95
    • Rotate the suction cup towards the indentation in the clamp's arm to release the pin.
    • You may need to use significant force and another hand to support the Anti-Clamp.
    • Remove the suction cup and its pin.
    • During reassembly, angle the pin into the hole across from the indent before pushing it back into the arm.
  3. How to Replace the Suction Cups for the Anti-Clamp, Remove the pin: 3 단계, 이미지 3개 중 1개 How to Replace the Suction Cups for the Anti-Clamp, Remove the pin: 3 단계, 이미지 3개 중 2개 How to Replace the Suction Cups for the Anti-Clamp, Remove the pin: 3 단계, 이미지 3개 중 3개
    • Pull the pin through the top of the suction cup and remove it.
결론
For other general electronics skills guides, click here.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
213,259 평판
안내서 1,040개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,638개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 10
지난 30일: 40
전체 시간: 1,183
