주요 콘텐츠로 건너뛰기
How to Replace the Temple Tips of a Pair of Eyeglasses
필요한 것
  1. How to Replace the Temple Tips of a Pair of Eyeglasses, Temple Tip: 1 단계, 이미지 1/1
    • Put all separated parts of the eyeglass including the eyeglass frame, temple tip on a clean and flat surface.
  2. How to Replace the Temple Tips of a Pair of Eyeglasses: 2 단계, 이미지 1/2 How to Replace the Temple Tips of a Pair of Eyeglasses: 2 단계, 이미지 2/2
    • Clean the temple and temple tip with alcohol wipes to make sure any glue residue is removed.
  3. How to Replace the Temple Tips of a Pair of Eyeglasses: 3 단계, 이미지 1/1
    • Drop a single drop of glue onto the end of the temple tip.
  4. How to Replace the Temple Tips of a Pair of Eyeglasses: 4 단계, 이미지 1/2 How to Replace the Temple Tips of a Pair of Eyeglasses: 4 단계, 이미지 2/2
    • Slide the temple tip into the end of the metal part of the eyeglass temple until you feel the metal part hits the bottom of the temple tip.
  5. How to Replace the Temple Tips of a Pair of Eyeglasses: 5 단계, 이미지 1/1
    • Hold it together for around one minute to keep it in the correction position.
  6. How to Replace the Temple Tips of a Pair of Eyeglasses: 6 단계, 이미지 1/1
    • Using a hairdryer on high heat, heat the temple tip to shrink it for roughly 3-6 minutes.
    • For safety, wear thick gloves during this step. It can protect you from burning your hand by the hot air of the hairdryer.
결론
Fixing a temple tip of eyeglasses is an uncomplicated process that you can do at home by yourself. Our instruction will have some steps, following:
다른 2명이 해당 안내서를 완성하였습니다.
ZHEHAO GUO
회원 가입일: 01/19/21
187 평판
안내서 1개 작성함
York University, Team S1-G11, Melo-Thaiss Winter 2021 York University, Team S1-G11, Melo-Thaiss Winter 2021 회원
YORK-MELO-THAISS-W21S1G11
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 91
30일 전: 403
전체 시간: 12,812
