이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Put all separated parts of the eyeglass including the eyeglass frame, temple tip on a clean and flat surface.
Clean the temple and temple tip with alcohol wipes to make sure any glue residue is removed.
Slide the temple tip into the end of the metal part of the eyeglass temple until you feel the metal part hits the bottom of the temple tip.
Hold it together for around one minute to keep it in the correction position.
Using a hairdryer on high heat, heat the temple tip to shrink it for roughly 3-6 minutes.
다른 2명이 해당 안내서를 완성하였습니다.
