주요 콘텐츠로 건너뛰기
How to Replace the Wax Ring on a Toilet
필요한 것
  1. How to Replace the Wax Ring on a Toilet, Wax Ring: 1 단계, 이미지 1/1
    • Turn off the water.
    • You do not want to forget this step.
  2. How to Replace the Wax Ring on a Toilet: 2 단계, 이미지 1/1
    • Disconnect the hose from the toilet by unscrewing the white plastic connector.
    • Excess water will spill out of this pipe, so have a bucket or rag nearby to catch it!
  3. How to Replace the Wax Ring on a Toilet: 3 단계, 이미지 1/1
    • Remove the plastic bolt protectors on either side of the base of the toilet.
    • Using a wrench, remove the nuts and washers from the bottom of the toilet where it's bolted to the floor.
    • Lift the toilet up from the floor.
    • Use caution when lifting it, it's going to be heavy!
    • Set the toilet off to the side.
  4. How to Replace the Wax Ring on a Toilet: 5 단계, 이미지 1/1
    • Remove the old wax ring and any debris from the toilet pipe in the floor where the toilet was, being sure not to let any debris fall down the pipe.
    • It may be nice to wear gloves for this step, as the old wax ring will be a bit dirty.
  5. How to Replace the Wax Ring on a Toilet: 6 단계, 이미지 1/1
    • Place new ring in the proper position for your toilet to rest on.
    • Carefully position the toilet back over the hole, paying attention to the bolts.
  6. How to Replace the Wax Ring on a Toilet: 7 단계, 이미지 1/1
    • Tighten the nuts and bolts on each side of the toilet and replace the bolt-protectors.
결론
Make sure you wash your hands!
Ahna Hensley
회원 가입일: 01/18/21
145 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 23
30일 전: 90
전체 시간: 1,882
