주요 콘텐츠로 건너뛰기
How to Replace the Wheels on an Office Chair
필요한 것
  1. How to Replace the Wheels on an Office Chair, Removing Casters: 1 단계, 이미지 1/1
    • Lay the chair down.
    • If the chair is too heavy to turn upside down, have someone help you do it.
  2. How to Replace the Wheels on an Office Chair: 2 단계, 이미지 1/1
    • Wipe the stem of the caster with a rag or paper towel to remove any dust or debris.
  3. How to Replace the Wheels on an Office Chair: 3 단계, 이미지 1/3 How to Replace the Wheels on an Office Chair: 3 단계, 이미지 2/3 How to Replace the Wheels on an Office Chair: 3 단계, 이미지 3/3
    • Use a flathead screwdriver in between the caster and the base of the chair to pry the wheel out of the socket.
    • Turn the screwdriver gently until the caster starts to move upwards away from the chair.
    • Try rotating the screwdriver at different angles if the caster won't come out.
  4. How to Replace the Wheels on an Office Chair: 4 단계, 이미지 1/3 How to Replace the Wheels on an Office Chair: 4 단계, 이미지 2/3 How to Replace the Wheels on an Office Chair: 4 단계, 이미지 3/3
    • Use a prying tool that is big enough to fit between the caster and over the stem.
    • Gently pull on the caster upwards and it should come off.
  5. How to Replace the Wheels on an Office Chair: 5 단계, 이미지 1/2 How to Replace the Wheels on an Office Chair: 5 단계, 이미지 2/2
    • Measure the wheel's height and length.
    • Once you've done that, purchase your new casters.
    • Large casters(about 3"), are more durable and versatile. Twin-wheel casters are usually used in office settings.
  6. How to Replace the Wheels on an Office Chair: 6 단계, 이미지 1/2 How to Replace the Wheels on an Office Chair: 6 단계, 이미지 2/2
    • Push the caster's stem into the bottom of chair leg.
    • Install the new casters.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Ismail Dhorre
회원 가입일: 01/10/21
160 평판
안내서 1개 작성함
York University, Team S1-G8, O'Regan Winter 2021 York University, Team S1-G8, O'Regan Winter 2021 회원
YORK-O'REGAN-W21S1G8
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 18
30일 전: 83
전체 시간: 5,331
