소개
She’s got fuel, she sparks, but she still won’t light. Your Zippo probably needs a new wick, here's how to replace your spent one.
필요한 것
Begin replacing the cotton, placing the last piece you pulled out in first and doing your best to replace them in the same position they were in before.
As you replace the cotton, weave the wick around each piece. This allows more wick to be inside the lighter, increasing its fuel capacity.
Be sure your work area is clear of any flammable liquids after you finish this replacement.
다른 20명이 해당 안내서를 완성하였습니다.
댓글 4개
The wick won't go into that tiny little hole so easily. It won't even get started enough to pull it through the other end. Trying to get it in there, frazzles the end of the wick which further makes it impossible to get it into the hole.
barbaraebj - 답글
Can't u just pull it up to get fresh wick?Call
مرحبا شكد سعار اكو توصيل العراق
عبوسي KING〆 - 답글
