주요 콘텐츠로 건너뛰기
How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla
필요한 것
  1. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla, Wiper Arm: 1 단계, 이미지 1/2 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla, Wiper Arm: 1 단계, 이미지 2/2
    • Take the tip of your flathead screwdriver, and wedge it underneath the wiper cap.
    • Firmly pry the wiper cap upwards until it's completely off.
  2. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 2 단계, 이미지 1/2 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 2 단계, 이미지 2/2
    • Place the head of your ratchet on the exposed nut.
    • Loosen the nut by turning your ratchet counter clockwise.
  3. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 3 단계, 이미지 1/2 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 3 단계, 이미지 2/2
    • Once the nut is loose enough, you may grab it and place it to the side.
  4. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 4 단계, 이미지 1/2 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 4 단계, 이미지 2/2
    • Firmly grip the lower end of the wiper arm.
    • Pull it towards you, so that the wiper arm is extended in the upward position.
  5. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 5 단계, 이미지 1/2 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 5 단계, 이미지 2/2
    • While holding the lower end of the wiper arm, tug the wiper arm upwards until completely detached.
    • Don't be discouraged if the wiper arm isn't detached right away. You may have to tug upwards a few times to detach it.
  6. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 6 단계, 이미지 1/2 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 6 단계, 이미지 2/2
    • Have your new wiper arm extended in the upward position (just how your old wiper arm was extended at the end of Step 4).
    • Take your wiper arm, and center its hole on the exposed metal threading.
  7. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 7 단계, 이미지 1/2 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 7 단계, 이미지 2/2
    • Once the wiper arm has been placed onto the metal threading, firmly grip the lower end of the wiper arm.
    • Slowly push the wiper arm downwards and away from you, so that it's flat with the windshield.
    • Make sure to do this slowly so that your fingers are not compressed by the wiper arm and the windshield.
  8. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 8 단계, 이미지 1/3 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 8 단계, 이미지 2/3 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 8 단계, 이미지 3/3
    • Place the same nut from earlier onto the exposed threaded metal.
    • Place the head of your ratchet onto the nut.
    • Tighten the nut by turning your ratchet clockwise, until it can no longer be tightened.
  9. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 9 단계, 이미지 1/3 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 9 단계, 이미지 2/3 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 9 단계, 이미지 3/3
    • Firmly press the wiper cap upon the exposed nut.
    • Once the wiper cap is secure, you may repeat steps 1-9 to the other wiper arm.
결론
Once you have replaced one of your wiper arms, repeat the same process for the remaining wiper arm.
다른 6명이 해당 안내서를 완성하였습니다.
Nicholas Imbriale
회원 가입일: 09/29/15
290 평판
안내서 1개 작성함
Cal Poly, Team 15-2, Green Fall 2015 Cal Poly, Team 15-2, Green Fall 2015 회원
CPSU-GREEN-F15S15G2
4 회원들
안내서 4개 작성하였습니다
댓글 한 개
good merci
thank you
Moad Mezzari - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 61
전체 시간: 9,697
