주요 콘텐츠로 건너뛰기
How to Replace the Xbox 360 Optical Drive Belt
필요한 것
  1. How to Replace the Xbox 360 Optical Drive Belt, Optical Drive Belt: 1 단계, 이미지 1/2 How to Replace the Xbox 360 Optical Drive Belt, Optical Drive Belt: 1 단계, 이미지 2/2
    • Remove the hard drive.
  2. How to Replace the Xbox 360 Optical Drive Belt: 2 단계, 이미지 1/3 How to Replace the Xbox 360 Optical Drive Belt: 2 단계, 이미지 2/3 How to Replace the Xbox 360 Optical Drive Belt: 2 단계, 이미지 3/3
    • Use a pry tool to gently remove the faceplate from the Xbox.
  3. How to Replace the Xbox 360 Optical Drive Belt: 3 단계, 이미지 1/3 How to Replace the Xbox 360 Optical Drive Belt: 3 단계, 이미지 2/3 How to Replace the Xbox 360 Optical Drive Belt: 3 단계, 이미지 3/3
    • Press down on the three holes as indicated to release the clips securing the base plate.
    • Remove the base plate.
    • Repeat this step on the other side.
  4. How to Replace the Xbox 360 Optical Drive Belt: 4 단계, 이미지 1/3 How to Replace the Xbox 360 Optical Drive Belt: 4 단계, 이미지 2/3 How to Replace the Xbox 360 Optical Drive Belt: 4 단계, 이미지 3/3
    • Repeat the previous step to remove the top plate of the Xbox.
  5. How to Replace the Xbox 360 Optical Drive Belt: 5 단계, 이미지 1/3 How to Replace the Xbox 360 Optical Drive Belt: 5 단계, 이미지 2/3 How to Replace the Xbox 360 Optical Drive Belt: 5 단계, 이미지 3/3
    • Gently unhook all four clips located on the front of the Xbox.
    • Take care not to break the plastic clips; it may be fragile.
  6. How to Replace the Xbox 360 Optical Drive Belt: 6 단계, 이미지 1/3 How to Replace the Xbox 360 Optical Drive Belt: 6 단계, 이미지 2/3 How to Replace the Xbox 360 Optical Drive Belt: 6 단계, 이미지 3/3
    • Use the flathead screwdriver to gently press down on all of the indicated indents.
    • Remove the top casing from the Xbox.
  7. How to Replace the Xbox 360 Optical Drive Belt: 7 단계, 이미지 1/3 How to Replace the Xbox 360 Optical Drive Belt: 7 단계, 이미지 2/3 How to Replace the Xbox 360 Optical Drive Belt: 7 단계, 이미지 3/3
    • Use the T3 Torx screwdriver to remove all six screws.
  8. How to Replace the Xbox 360 Optical Drive Belt: 8 단계, 이미지 1/3 How to Replace the Xbox 360 Optical Drive Belt: 8 단계, 이미지 2/3 How to Replace the Xbox 360 Optical Drive Belt: 8 단계, 이미지 3/3
    • Carefully flip over the Xbox to the other side.
    • Lift the Xbox casing off.
  9. How to Replace the Xbox 360 Optical Drive Belt: 9 단계, 이미지 1/3 How to Replace the Xbox 360 Optical Drive Belt: 9 단계, 이미지 2/3 How to Replace the Xbox 360 Optical Drive Belt: 9 단계, 이미지 3/3
    • Unplug the two connections in the rear of the disk drive.
  10. How to Replace the Xbox 360 Optical Drive Belt: 10 단계, 이미지 1/3 How to Replace the Xbox 360 Optical Drive Belt: 10 단계, 이미지 2/3 How to Replace the Xbox 360 Optical Drive Belt: 10 단계, 이미지 3/3
    • Use a flat screwdriver to remove the four screws underneath the disc drive.
    • Flip over the DVD disc drive and remove the casing.
  11. How to Replace the Xbox 360 Optical Drive Belt: 11 단계, 이미지 1/3 How to Replace the Xbox 360 Optical Drive Belt: 11 단계, 이미지 2/3 How to Replace the Xbox 360 Optical Drive Belt: 11 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Spin the located area with the flathead screwdriver to open up the disc drive.
    • Use tweezers to remove the belt drive.
  12. How to Replace the Xbox 360 Optical Drive Belt: 12 단계, 이미지 1/3 How to Replace the Xbox 360 Optical Drive Belt: 12 단계, 이미지 2/3 How to Replace the Xbox 360 Optical Drive Belt: 12 단계, 이미지 3/3
    • Replace with a new drive belt.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Angel Lopez
회원 가입일: 02/28/23
237 평판
안내서 1개 작성함
Austin Community College, Team 60-7, Watkins Spring 2023 Austin Community College, Team 60-7, Watkins Spring 2023 회원
AUSTINCC-WATKINS-S23S60G7
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 13
7일 전: 91
30일 전: 323
전체 시간: 3,382
