This guide will demonstrate how to increase the life of the air filter for the Honda HRR216 lawnmower.
Maintaining the filter is something that I do after every summer due to how often I use the lawnmower.
Steps 1,2,5, and 6 in this guide can also be used for removing or replacing the filter, as it will eventually wear down.
Make sure that the motor is off and has had time to cool after being used.
Push in the clips on the top of the cover, and remove the cover.
Seat the filter in the same position you made a note of in Step 2.
If the filter is still bent from cleaning it, lightly bend it in the opposite direction so that it can lay flat in your hand.
Place the cover onto the air filter. This shouldn't require any force, so the filter may need to be readjusted if it does require force.
Push the clips of the cover in until they click.
Check to make sure that the cover is secure, and there are no gaps for dirt or dust to get in.
해당 안내서 넣기
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
미리보기
