주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Repress a Broken Makeup Compact
필요한 것
    1. How to Repress a Broken Makeup Compact, How to Repress a Broken Makeup Compact: 1 단계, 이미지 2개 중 1개 How to Repress a Broken Makeup Compact, How to Repress a Broken Makeup Compact: 1 단계, 이미지 2개 중 2개
      • If some of the product remains unbroken, break it down using a toothpick . Completely crush the powder for a smooth fix.
      댓글 쓰기
    2. How to Repress a Broken Makeup Compact: 2 단계, 이미지 2개 중 1개 How to Repress a Broken Makeup Compact: 2 단계, 이미지 2개 중 2개
      • Add a few drops of rubbing alcohol to the broken product (the amount differs based on how much product you have left) and then thoroughly mix the alcohol into the powder with a toothpick.
      댓글 쓰기
    3. How to Repress a Broken Makeup Compact: 3 단계, 이미지 1개 중 1개
      • Place plastic wrap over the product and pull taut to reduce wrinkles in the plastic wrap.
      댓글 쓰기
    4. How to Repress a Broken Makeup Compact: 4 단계, 이미지 2개 중 1개 How to Repress a Broken Makeup Compact: 4 단계, 이미지 2개 중 2개
      • Press and smooth the product out using your finger or a spoon.
      • This may take some patience depending on how smooth you would like your product to turn out.
      댓글 쓰기
    5. How to Repress a Broken Makeup Compact: 5 단계, 이미지 1개 중 1개
      • Once smoothed, remove the plastic wrap and allow the compact to dry for 6-8 hours.
      • Pro tip: If you need to use your product soon, you can speed up drying time by using a hairdryer on low heat!
      댓글 쓰기
    6. How to Repress a Broken Makeup Compact: 6 단계, 이미지 2개 중 1개 How to Repress a Broken Makeup Compact: 6 단계, 이미지 2개 중 2개
      • Lastly, enjoy your product! It provides the same pigment and performance as it once did before the break.
      댓글 쓰기
결론
This method will save you money and preserve your favorite powder products without compromising its quality or pigment. I hope you found my guide useful.
Your friendly makeup lover,
Alexis
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alexis Wilhelm
회원 가입일: 05/01/20
181 평판
안내서 1개를 작성함
UW Tacoma, Team S1-G49, Cardinal Spring 2020 UW Tacoma, Team S1-G49, Cardinal Spring 2020 회원
UWT-CARDINAL-S20S1G49
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 64
전체 시간: 4,212
