소개
Is your Schlage Connect not working? You may need to reset the device to factory settings. Can't find the user guide for instructions? This guide will help you!
Device model: Schlage Connect BE469IR
Why this guide? This guide provides easy-to-follow steps to reset your device. No user guide is required.
What does this guide provide? Twelve quick steps to reset the device to factory settings without a user guide.
Note: Before resetting the device, you will need your device's original factory's preset user code. You can find this code either in the device's user guide or on the back of the device's inside cover. Steps 3-6 will show you how to do this without the user guide.
Need Additional Resources? Go to Schlage's YouTube Channel.
필요한 것
Ensure the latch is retracted (not locked).
다른 2명이 해당 안내서를 완성하였습니다.
