주요 콘텐츠로 건너뛰기
How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard
필요한 것
  1. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard, How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 1 단계, 이미지 1개 중 1개
    • Unplug the computer from the power supply before disassembly.
    • Wait 5 minutes after the device has been powered off.
  2. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 2 단계, 이미지 3개 중 1개 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 2 단계, 이미지 3개 중 2개 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 2 단계, 이미지 3개 중 3개
    • Using a Phillips #1 screwdriver, remove two screws that would grant access to inner components of your computer.
    • Remove the side panel of the computer tower to access the inner components. Slide the panel then lift it to safely remove it.
    • Removing the panel may be different for your computer.
  3. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 3 단계, 이미지 3개 중 1개 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 3 단계, 이미지 3개 중 2개 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 3 단계, 이미지 3개 중 3개
    • Using the Phillips #1 screwdriver, remove the screw holding the graphics card (GPU) onto the motherboard.
    • Disconnect any power cables that may be attached to your graphics card.
    • Carefully slide the graphics card out from its slot.
  4. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 4 단계, 이미지 2개 중 1개 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 4 단계, 이미지 2개 중 2개
    • Remove the CMOS Battery using a plastic opening tool.
    • There may be a spring mechanism available to use to easily remove the battery.
  5. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 5 단계, 이미지 1개 중 1개
    • Wait 5 minutes to allow enough time for the power to cycle through.
  6. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 6 단계, 이미지 1개 중 1개
    • Insert battery back into position with the flat side facing upwards.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Andrew Barsoom
회원 가입일: 01/17/21
189 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 19
지난 30일: 93
전체 시간: 6,530
