소개
This guide will show you how to reset the automatic mechanism of your Audio Technica AT-LP60BK turntable’s needle. This fix involves no replacement parts and is an incredibly easy fix to execute. The one tool you will need is a Phillips head screwdriver. Use this screwdriver to unscrew the central screw in the middle white gear. Have a cup or bin ready to secure the screw and make sure to carefully remove the central white gear revealing the automatic mechanism. Carefully handle the parts of the turntable disk to prevent any parts from breaking.
필요한 것
Carefully remove the plastic cover and set aside.
