주요 콘텐츠로 건너뛰기
How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable
필요한 것
  1. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable, How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 1 단계, 이미지 1/2 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable, How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 1 단계, 이미지 2/2
    • Carefully remove the plastic cover and set aside.
  2. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 2 단계, 이미지 1/3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 2 단계, 이미지 2/3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 2 단계, 이미지 3/3
    • Remove the pad if there is one.
    • Spin the turntable until the belt and drive motor can be seen through a hole.
    • Gently pull the belt off of the motor, and make sure that the belt doesn’t bend or flip over.
    • Take off the turntable platter and set aside.
  3. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 3 단계, 이미지 1/3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 3 단계, 이미지 2/3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 3 단계, 이미지 3/3
    • Remove the single screw from the middle white gear with a Phillips #00 screwdriver.
    • Have a cup or bin so you don’t lose the screw!
    • Gently pull the gear out, revealing the automatic mechanism.
  4. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 4 단계, 이미지 1/3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 4 단계, 이미지 2/3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 4 단계, 이미지 3/3
    • Push the metal part away from the center. It should click into place.
    • Push the small metal part back to the center, towards the gear axle.
    • Push the metal part inward, close to the gear’s mounting point.
  5. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 5 단계, 이미지 1/1
    • Replace the gear, making sure that the the metal latch on the gear is pushed back.
    • The central shaft should spin freely without hooking the gear.
    • Don't forget to put the band back on the drive motor when reassembling.
결론
Devin Hoopes
회원 가입일: 09/08/21
121 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 58
전체 시간: 2,452
