주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Reshape a Warped Nail Polish Brush
필요한 것
    1. How to Reshape a Warped Nail Polish Brush, How to Reshape a Warped Nail Polish Brush: 1 단계, 이미지 2개 중 1개 How to Reshape a Warped Nail Polish Brush, How to Reshape a Warped Nail Polish Brush: 1 단계, 이미지 2개 중 2개
      • Remove the nail polish brush from bottle.
      • Wrap the bottle of nail polish with aluminum foil to prevent the polish from drying.
      댓글 쓰기
    2. How to Reshape a Warped Nail Polish Brush: 2 단계, 이미지 2개 중 1개 How to Reshape a Warped Nail Polish Brush: 2 단계, 이미지 2개 중 2개
      • Wipe the brush clean with a paper towel.
      댓글 쓰기
    3. How to Reshape a Warped Nail Polish Brush: 3 단계, 이미지 2개 중 1개 How to Reshape a Warped Nail Polish Brush: 3 단계, 이미지 2개 중 2개
      • Clean the brush in small amount of 100% pure acetone in a glass bowl.
      • DO NOT USE ANY OTHER TYPE OF CONTAINER MATERIALS OTHER THAN GLASS or PORCELAIN FOR ACETONE. Acetone is a chemical that will damage the plastic’s surface by softening it, smearing it, or even dissolving the plastic.
      댓글 쓰기
    4. How to Reshape a Warped Nail Polish Brush: 4 단계, 이미지 1개 중 1개
      • Blow-dry the brush on medium-low heat from brush base to tip for 30-90 seconds.
      댓글 쓰기
    5. How to Reshape a Warped Nail Polish Brush: 5 단계, 이미지 3개 중 1개 How to Reshape a Warped Nail Polish Brush: 5 단계, 이미지 3개 중 2개 How to Reshape a Warped Nail Polish Brush: 5 단계, 이미지 3개 중 3개
      • Reshape the warm bristles by hand or press in a book, rotating as needed.
      • You can reheat the bristles if they are not yet flattened into the desired shape.
      댓글 쓰기
결론
Test a swatch on a piece of paper to check the shape of the brush with the nail polish. If the shape is not yet to its desired form, restart the guide to reshape the brush.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Michelle Nguyen
회원 가입일: 09/28/22
130 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 27
지난 30일: 84
전체 시간: 2,276
