주요 콘텐츠로 건너뛰기
How to Resize Pants
필요한 것
  1. How to Resize Pants, How to Resize Pants: 1 단계, 이미지 1/1
    • Put on the pants inside out.
  2. How to Resize Pants: 2 단계, 이미지 1/1
    • Safety pin the waistband of the pants to the desired fit.
  3. How to Resize Pants: 3 단계, 이미지 1/1
    • Pin the outside seam around both hips so that the pants are snug.
  4. How to Resize Pants: 4 단계, 이미지 1/2 How to Resize Pants: 4 단계, 이미지 2/2
    • Pin down the back seam and inseam so that the pants fit comfortably.
  5. How to Resize Pants: 5 단계, 이미지 1/1
    • Take the pants off. Sew the back seam, following your pins.
    • Be careful when operating a sewing machine.
  6. How to Resize Pants: 6 단계, 이미지 1/1
    • Put the pants on. Pin the rest of the inseam and the outside seam down both legs.
    • Our preference was to use the skinny jean cut. However, this sewing technique can be applied to any jean cut by simply adjusting the snugness of the fit as you pin.
  7. How to Resize Pants: 7 단계, 이미지 1/1
    • Take the pants off. Then, cut off the extra fabric.
    • If you prefer, iron your newly created seams so that they lay open.
  8. How to Resize Pants: 8 단계, 이미지 1/1
    • Enjoy your newly fitted pair of pants!
결론
After following these steps, you should have properly fitting pants that were ill-fitting before.
다른 18명이 해당 안내서를 완성하였습니다.
Haleigh Bingham
회원 가입일: 09/14/15
503 평판
안내서 1개 작성함
Sam Houston State, Team 15-5, Nardone Fall 2015 Sam Houston State, Team 15-5, Nardone Fall 2015 회원
SHSU-NARDONE-F15S15G5
4 회원들
안내서 6개 작성하였습니다
댓글 4개
Thank you for this! I have a pair I really like that are huge in the hip and butt. So is it best to pin and make them fit better using the inseam, or the outside seam?
Matt and Amy Crowell - 답글
Thank you, I used your guide for my first time fitting pants; it was absolutely helpful!
Angelica Murillo - 답글
Muy original y más fácil de lo que había visto. A pesar que me defiendo bastante bien con la costura, esto de cambiar de una talla XL a una S, no lo hice nunca en un short, así que gracias por compartir tus conocimientos.
Ros CH - 답글
para que no se deshilen los bordes hay que darle unas puntadas en forma de zig zag a todos los bordes que se cortan.
DAVID MORENO - 답글
댓글 쓰기
조회 통계:
24 시간 전: 15
7일 전: 132
30일 전: 642
전체 시간: 133,899
