주요 콘텐츠로 건너뛰기
How to Resize a Metal Ring that is Too Large
필요한 것
  1. How to Resize a Metal Ring that is Too Large, How to Resize a Metal Ring that is Too Large: 1 단계, 이미지 1/2 How to Resize a Metal Ring that is Too Large, How to Resize a Metal Ring that is Too Large: 1 단계, 이미지 2/2
    • Find the metal ring that is too large for your finger.
  2. How to Resize a Metal Ring that is Too Large: 2 단계, 이미지 1/2 How to Resize a Metal Ring that is Too Large: 2 단계, 이미지 2/2
    • Tear off a quarter size of soft clay.
    • The soft clay will act as a mold that will enlarge the metal ring.
  3. How to Resize a Metal Ring that is Too Large: 3 단계, 이미지 1/3 How to Resize a Metal Ring that is Too Large: 3 단계, 이미지 2/3 How to Resize a Metal Ring that is Too Large: 3 단계, 이미지 3/3
    • Wear the metal ring.
    • Place the back of your hand flat on a table.
    • Shape the soft clay snugly in the gap between the metal ring and your finger.
  4. How to Resize a Metal Ring that is Too Large: 4 단계, 이미지 1/3 How to Resize a Metal Ring that is Too Large: 4 단계, 이미지 2/3 How to Resize a Metal Ring that is Too Large: 4 단계, 이미지 3/3
    • Remove your finger slowly from the molded soft clay, immediately after shaping the soft clay.
    • If the molded soft clay shifts then repeat Step 3.
    • Wait for the soft clay to dry overnight.
    • To tell if the soft clay is dry, touch the soft clay to see if it has hardened.
  5. How to Resize a Metal Ring that is Too Large: 5 단계, 이미지 1/3 How to Resize a Metal Ring that is Too Large: 5 단계, 이미지 2/3 How to Resize a Metal Ring that is Too Large: 5 단계, 이미지 3/3
    • Remove the soft clay mold from the metal ring.
  6. How to Resize a Metal Ring that is Too Large: 6 단계, 이미지 1/2 How to Resize a Metal Ring that is Too Large: 6 단계, 이미지 2/2
    • Use scissors to trim the mold's extra soft clay sticking out of the metal ring.
  7. How to Resize a Metal Ring that is Too Large: 7 단계, 이미지 1/3 How to Resize a Metal Ring that is Too Large: 7 단계, 이미지 2/3 How to Resize a Metal Ring that is Too Large: 7 단계, 이미지 3/3
    • Limit super glue exposure from skin as it may cause a rash. If super glue comes into contact with skin, soak the skin in warm, soapy water.
    • Adhere super glue on the soft clay mold that will touch the metal ring.
    • Attach the soft clay mold to the metal ring before the super glue dries.
  8. How to Resize a Metal Ring that is Too Large: 8 단계, 이미지 1/3 How to Resize a Metal Ring that is Too Large: 8 단계, 이미지 2/3 How to Resize a Metal Ring that is Too Large: 8 단계, 이미지 3/3
    • Wait 10 minutes for the super glue to dry.
    • Trim the soft clay with scissors again, if needed.
    • The goal of this step is to align the soft clay mold along the metal ring's band.
  9. How to Resize a Metal Ring that is Too Large: 9 단계, 이미지 1/2 How to Resize a Metal Ring that is Too Large: 9 단계, 이미지 2/2
    • If completed, the metal ring should fit!
결승점
Helena Sherman
회원 가입일: 02/18/20
169 평판
안내서 1개 작성함
UC Davis, Team S2-G1, Andersen Winter 2020 UC Davis, Team S2-G1, Andersen Winter 2020 회원
UCD-ANDERSEN-W20S2G1
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 8
전체 시간: 319
