주요 콘텐츠로 건너뛰기
How to Restain Wood
필요한 것
  1. How to Restain Wood, How to Restain Wood: 1 단계, 이미지 1개 중 1개
    • Wipe down the wood with a rag or a towel to take clean the wood.
  2. How to Restain Wood: 2 단계, 이미지 1개 중 1개
    • Sand down the wood until you get a soft surface.
    • If your wood is already stained, then sand the wood until it is clear of the old stain.
  3. How to Restain Wood: 3 단계, 이미지 1개 중 1개
    • Wipe down the sanded part with the rag so when you paint on the wood you don't get the brush dirty with dust from the wood.
  4. How to Restain Wood: 4 단계, 이미지 1개 중 1개
    • Paint the wood and make sure to cover all surfaces of the wood.
    • Let it dry and repaint the wood a couple more times to ensure all of the surfaces have been properly coated.
결론
To do this process again just follow these steps again and this process should be done again in 6-7 months
작성자
2다른 기여자 명과 함께
Brian Morales
회원 가입일: 10/23/20
109 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 5
지난 30일: 10
전체 시간: 424
