주요 콘텐츠로 건너뛰기
How to Restore Wool’s Water Resistance
필요한 것
  1. How to Restore Wool’s Water Resistance, How to Restore Wool’s Water Resistance: 1 단계, 이미지 3개 중 1개 How to Restore Wool’s Water Resistance, How to Restore Wool’s Water Resistance: 1 단계, 이미지 3개 중 2개 How to Restore Wool’s Water Resistance, How to Restore Wool’s Water Resistance: 1 단계, 이미지 3개 중 3개
    • Fill a bowl with water at room temperature (20 °C or 68 °F).
    • Use 2 L of water per 200 g of wool.
  2. How to Restore Wool’s Water Resistance: 2 단계, 이미지 1개 중 1개
    • Add 1/2 teaspoon of wool wash per 2 L of water.
  3. How to Restore Wool’s Water Resistance: 3 단계, 이미지 2개 중 1개 How to Restore Wool’s Water Resistance: 3 단계, 이미지 2개 중 2개
    • Insert the articles into the bowl and let soak for 30 minutes.
    • Carefully squeeze the items to allow absorption of soap and water through the wool fibres.
  4. How to Restore Wool’s Water Resistance: 4 단계, 이미지 1개 중 1개
    • Lift the items out of the water and gently squeeze to remove excess water and soap.
  5. How to Restore Wool’s Water Resistance: 5 단계, 이미지 1개 중 1개
    • Refill the bowl with room temperature water.
    • Use the same volume of water as in Step 1.
  6. How to Restore Wool’s Water Resistance: 6 단계, 이미지 2개 중 1개 How to Restore Wool’s Water Resistance: 6 단계, 이미지 2개 중 2개
    • Mix 4 tablespoons of emulsified lanolin into 2 liters of water.
  7. How to Restore Wool’s Water Resistance: 7 단계, 이미지 2개 중 1개 How to Restore Wool’s Water Resistance: 7 단계, 이미지 2개 중 2개
    • Add the articles and squeeze to saturate.
    • Weight the articles with a heavy glass or a dish.
    • Leave to soak for 30 minutes.
  8. How to Restore Wool’s Water Resistance: 8 단계, 이미지 2개 중 1개 How to Restore Wool’s Water Resistance: 8 단계, 이미지 2개 중 2개
    • Pull the articles out of the lanolin bath and gently squeeze out excess water.
  9. How to Restore Wool’s Water Resistance: 9 단계, 이미지 1개 중 1개
    • Lay flat to dry with a clean towel beneath the items.
    • Do not line dry. It can cause wool to stretch and lose shape.
    • Avoid direct sunlight or direct heat when drying.
결승점
작성자
1다른 기여자 명과 함께
Yuliya S
회원 가입일: 01/17/22
169 평판
안내서 1개를 작성함
York University, Team 1-26, O'Regan Winter 2022 York University, Team 1-26, O'Regan Winter 2022 회원
YORK-O'REGAN-W22S1G26
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 41
전체 시간: 779
